Front & Rear differential & transfer case service
Results 1 to 12 of 12
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, Front & Rear differential & transfer case service in Cadillac Escalade Forums; What should I expect to pay for front & rear differential & transfer case service? Just looking for an idea. ...
    383 LT1 SS is offline Cadillac Owners Fanatic
    Automobile(s): 1996 Impala SS 383 LT1 2011 Escalade ESV 2008 DTS
    May 2010
    NW Burbs of Chicago
    197
    Thanks
    383 LT1 SS
    SJG3RD is offline Cadillac Owners Member
    Automobile(s): Escalade
    Feb 2009
    Fayetteville, AR
    35
    23
    Re: Front & Rear differential & transfer case service
    Do it yourself it is easy with basic hand tools. Drain and refill the front, on the rear I removed the cover, cleaned and reinstalled with new gasket and refilled in about one hour.
    I went with Amsoil 75w-90 Severe Gear in the front and rear.
    Anyone with a 96 Impala with a 383 can do it, I use to have one myself. Man I miss that car.
    ToddEdge is offline Cadillac Owners Member
    Automobile(s): 2007 Escalade AWD
    Oct 2013
    41
    75
    I know in TN, the 50K service includes the differentials, transfer case, and the transmission and is $700.
    For the diffs, can you use any 75W90 gear fluid or does it need non-slip additives?
    Thanks,
    Todd
  5. #4
    Feb 2009
    Fayetteville, AR
    35
    23
    You can use any 75w-90, I would recommend a good synthetic: Mobil 1, Amsoil. etc... no additives needed for the rear end.
  6. #5
    Oct 2013
    41
    75
    Quote Originally Posted by SJG3RD View Post
    How about the front diff? I assume the same.
    Thanks,
    Todd
  7. #6
    rgb129 is offline Cadillac Owners Member
    Automobile(s): 2009 Escalade
    Jun 2013
    50
    It is the same.
  8. #7
    wesyder's Avatar
    wesyder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
    Mar 2009
    Eastvale Calif
    1,793
    We totally missed the transfer case lol
  9. #8
    Feb 2009
    Fayetteville, AR
    35
    23
    Dang we did. I used the GM Blue All Wheel Drive Fluid. I am not sure what the correct name or part number is. 2 quarts and actual will be able 1.75 quarts before it starts to run back out of the fill hole.
    Hope it helps.
  10. #9
    kazza93203's Avatar
    kazza93203 is offline Cadillac Owners Fanatic
    Automobile(s): 07 Escalade
    Aug 2011
    29
    190
    Has anyone used trans fluid in the transfer case? Mitchell on demand states to use trans fluid?
  11. #10
    May 2010
    NW Burbs of Chicago
    197
    I have decided to tackle this job on my own. Can anybody who has done this tell me if the rear differential has a drain plug or do I need to purchase a gasket? Have not been able to get under the truck due to the weather.
    Thanks-
    383 LT1 SS
  12. #11
    Feb 2009
    Fayetteville, AR
    35
    23
    No drain plug just a fill hole. I replaced the gasket but mine probably could have been reused. I replaced anyway since I had already bought one. Got it from Autozone for around $35(Felpro rubber). I pulled the cover entirely and cleaned it off, there is a magnet attached to the cover and it had metal debris attached to it. Clean it off well with brake cleaner, installed new gasket and refilled. Should hold almost 3 quarts. Buy a hand held pump to make refill simple. I got the pump at Autozone as well for about $10.
  13. #12
    wesyder's Avatar
    Mar 2009
    Eastvale Calif
    1,793
    Quote Originally Posted by kazza93203
    Yes ATF Dexron III should be ok
  14. Remove Advertisements
