Brake rotors and pads
Results 1 to 11 of 11
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, Brake rotors and pads in Cadillac Escalade Forums; I installed new slotted and drilled rotors along with ceramic pads back in sept 2013 and they squeak very loud ...
    xlraw is offline Cadillac Owners Member
    Oct 2011
    73
    I installed new slotted and drilled rotors along with ceramic pads back in sept 2013 and they squeak very loud when moving at low speeds and first thing in the morning. I am wondering if they are any solutions to this problem or just switch to standard rotors. The old standard rotors I had were worn but never squeak like these ones. The ones I used are max performance brakes.
    SpyShops NY's Avatar
    SpyShops NY is offline Cadillac Owners Enthusiast
    Automobile(s): 1999 Escalade, 2004 CTS, 2003 ESV, Now 2008 Escalade
    Oct 2012
    Fresh Meadows, NY
    38
    790
    Get wagnor pads or dealer pads it's the pads
    Oct 2012
    Fresh Meadows, NY
    38
    790
    It's the pads I also have cross drilled and slotted and I changed the pads to wagnor thermal quiet good now
    Oct 2011
    73
    What about akebono pads which ones would you recommend
    Oct 2012
    Fresh Meadows, NY
    38
    790
    Re: Brake rotors and pads
    wagnor or dealer I have seen brembo pads on ebay but I never tried those
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2012 Escalade, 2014 SRX
    Apr 2003
    H.V., Pa/Town of Webb, NY
    13,274
    It's all about the break in when it comes to squeals and other brake noises, also could be a problem with the install and the pads are making a vibration that can make a squealing sound on some ceramics. You may have a glaze on the pad causing this noise, if that is the case the pads should be removed and slightly sanded to remove the glaze.
    quattrotman's Avatar
    quattrotman is offline Cadillac Owners Fanatic
    Automobile(s): 07 Escalade EXT
    Jul 2011
    Vancouver BC
    45
    357
    Those max performance pads are crap. I had them too and they squealed like crazy. I changed to Hawk ceramic and they are fine now and stop way better. The rotors from Max are ok but the pads are no good.
    dcarrer0 is offline Cadillac Owners Member
    Automobile(s): 2008 escalade esv
    Dec 2013
    44
    I just replaced my rear rotors and pads. I couldnt mess it up...i went om. All is great!
    Oct 2011
    73
    If I just change the pads do I have to break them in. The rotors are slotted and drilled and have a film on them.
    Jul 2011
    Vancouver BC
    45
    357
    You always need to break in (bed) new pads.
    Apr 2003
    13,274
    As said above there should be instructions included with the pads on bedding, if not look at their web site, this is important and will usually prevent glazing which causes squeals and other unpleasant brake noises
  14. Remove Advertisements
