Trouble Codes p0496 and p0455 2007 Escalade EXT
Results 1 to 4 of 4
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, Trouble Codes p0496 and p0455 2007 Escalade EXT in Cadillac Escalade Forums; I already changed the gas cap cause the DIC said to tighten it, so I thought it was bad. Bought ...
    big rob 1's Avatar
    big rob 1 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 EXT
    Nov 2010
    Bay Area, CA
    410
    I already changed the gas cap cause the DIC said to tighten it, so I thought it was bad. Bought a new AC Delco one, same problem.
    Pulled the codes last night and was told:
    P0496 and P0455 are there.
    What do I need to but to fix it.
    Thanks
    SpyShops NY's Avatar
    SpyShops NY is offline Cadillac Owners Enthusiast
    Automobile(s): 1999 Escalade, 2004 CTS, 2003 ESV, Now 2008 Escalade
    Oct 2012
    Fresh Meadows, NY
    38
    800
    You need a purge valve 40$ and a evap canister that had to be modified from Gm poor design this was a mistake Gm made since a canister is suppose to last 20 yr plus. Don't forget the wire adapter can fix for under 200$
    big rob 1's Avatar
    Nov 2010
    Bay Area, CA
    410
    Re: Trouble Codes p0496 and p0455 2007 Escalade EXT
    Quote Originally Posted by SpyShops NY View Post
    thanks for the help, any part #'s?
    I am going to look at rock auto and see if I can find them.
    found this for the purge valve, http://www.amazon.com/ACDelco-214-16.../dp/B000NWA6T0 (where is it located on an EXT)??
    Oct 2012
    Fresh Meadows, NY
    38
    800
    you have to go to dealer for these parts no autozone or aftermarket store will have this dealer parts only sucks
  7. Remove Advertisements
