Firm up the shifts (handheld flash)
Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By big rob 1
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, Firm up the shifts (handheld flash) in Cadillac Escalade Forums; I have a 2007 Escalade EXT and it has the 6 speed transmission. I am wondering if there is some ...
    big rob 1's Avatar
    big rob 1 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 EXT
    Nov 2010
    Bay Area, CA
    410
    I have a 2007 Escalade EXT and it has the 6 speed transmission. I am wondering if there is some kind of tuner to flash the ECU and give it the option to firm up the transmission shifts?
    Thanks
    Rob
    quattrotman's Avatar
    quattrotman is offline Cadillac Owners Fanatic
    Automobile(s): 07 Escalade EXT
    Jul 2011
    Vancouver BC
    46
    357
    Re: Firm up the shifts (handheld flash)
    My Diablo Intune allows me to configure shift points and firmness. There are 3 settings for normal, firm and hard. I am very pleased with the tuner overall.
    big rob 1's Avatar
    Nov 2010
    Bay Area, CA
    410
    Quote Originally Posted by quattrotman View Post
    Have you used any of the firmness settings before?
    I saw the Diablo InTune allows this change, but wasn't sure how FIRM it would be.
    Can you share any real world experience?
    Thanks!
    Jul 2011
    Vancouver BC
    46
    357
    I had it set to Hard shifts and it is very firm. So much so that I changed it to firm instead because I was worried I was going to do some damage over time. It is a very noticeable difference though and you can change (by RPM) how long the gear holds. With the diablo tune, I think it was well worth the $400 for me.
    nixonride is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Nov 2007
    180
    I would recommend a tune from Westers....hits way more parameters than a diablo and cost is about the same...you will get more power, better fuel mileage and stiffer/stronger shift points.
    CUTiger78's Avatar
    CUTiger78 is offline Cadillac Owners Fanatic
    Automobile(s): 2011 ESV Premium
    Jul 2006
    NoVA
    101
    Driving in the trailer towing mode will firm up the shifts.
    big rob 1's Avatar
    Nov 2010
    Bay Area, CA
    410
    Thanks for this information, I will have to give it a try. you have been a big help!
    quattrotman likes this.
    Cadsrfun is offline Cadillac Owners Member
    Automobile(s): 2010 Silver Escalade ESV Platinum
    Jan 2012
    Templeton CA
    61
    I also have the intune but I don't recall being able to change the shifts. I installed the diablo tune and it did firm the shifts up but I wouldn't mind firmer. I have had my programmer for about a year. Is yours newer with new features? Thanks
    satlite440 is offline Cadillac Owners Member
    Automobile(s): tec at brotherton cadillac
    Nov 2013
    48
    33
    tuners will help some but the only way to really fix it is to tear it down and put thicker selectable snaprings in the cluches
    Jan 2012
    Templeton CA
    61
    Quote Originally Posted by satlite440 View Post
    Usually but read post #4...
    Jul 2011
    Vancouver BC
    46
    357
    Quote Originally Posted by Cadsrfun View Post
    I have had it for over a year myself. Not sure why you aren't seeing this, it is part of the adjustable parameters. You can adjust shift points and shift firmness...as well as other parameters like speedo calibration for bigger wheels and rev limiter etc.
    Jan 2012
    Templeton CA
    61
    I bet I know why now. I believe that I selected the 'diablo tune" instead of the "adjustable parameters". I was worried that I didn't know enough about the tuning of the engine to go into that mode. The diablo tune was generated on a dyno using somebody on this forum with Diablo Sport and they made it part of the menu of the programmer. Thanks for your help.
  15. Remove Advertisements
