Service Stabilitrak and reduced engine power
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 22
Like Tree1Likes
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, Service Stabilitrak and reduced engine power in Cadillac Escalade Forums; I got this message while on the highway. Couldn't go more that 40 mph. The dealer said it was the ...
    escalade kidd is offline Cadillac Owners Fanatic
    Automobile(s): 2009 Escalade EXT
    Apr 2010
    NJ
    55
    139
    I got this message while on the highway. Couldn't go more that 40 mph. The dealer said it was the Throttle Position Sensor. My warranty was done but they said that part has an extended warranty on it. No charge.
    new york city's Avatar
    new york city is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Escalade ESV
    Oct 2013
    28
    268
    Re: Service Stabilitrak and reduced engine power
    This is by far the worst problem with these cars. No other problem beats this. Do a search on this and witness the devastation this issue causes.
    If the dealer is doing it for free then you better run as fast as you can to have them do it.
    Read my thread on this. Dealer said the same exact thing "Throttle Position Sensor" and they ended up removing the entire engine block because the oil was not lubricating... (it's a long story and various parts & various visits to the dealer for this issue, my thread explains everything)
    themunsta is offline Cadillac Owners Member
    Jan 2014
    5
    My 2007 Escalade is having the same issue. Still waiting to hear from Dealer. Its been there for 3 Days so far!!!!. From I have been reading, this sounds like its going to be an Absolute Nightmare
    MRANT212's Avatar
    MRANT212 is offline Cadillac Owners Fanatic
    Automobile(s): 15 Escalade 2014 Audi S6,08 SS,88Corvette,71Corvette
    Nov 2005
    55
    405
    Anyone know if the throttle position sensor would shut the truck off? Just got a phone call from my wife a few minutes ago. Stabilitrak light came on and the truck just shut down. She was at stop sign and turned the truck off and restarted it. I'm taking it to my dealership in a bit. Hope it makes it
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    48
    11,051
    Reduced engine power is related to a failure of a specific system, the "drive by wire" throttle control.
    Faults related to performance of the TP sensors or APP sensor (accelerator pedal position) will set codes and cause the vehicle to enter one of a few power reduction modes.
    If this happens you can get to the side of the road and turn the key off for a minute, then restart and drive normally. Typically this fault is fairly intermittent which makes it difficult to diagnose.
    The TP sensor is usually integrated into the throttle. The special policy our OP spoke of is related to a specific design that allows you to service the "cover" which contains the sensor and drive mechanism for the throttle plate.
    Most are serviced by replacing the throttle body, which is not hard to do. However often times it can be a wiring or terminal contact issue. This typically requires rewiring the circuits from the throttle body to the controller and using new terminals from the repair kit that dealerships have. It can be time consuming and requires the proper type and size of wiring.
    It can be a daunting task to fix one of these that acts up intermittently. If a dealer or any shop "best guesses" this, ask them how they will stand behind their diagnosis if it happens again.
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,683
    Quote Originally Posted by escalade kidd View Post
    Hello escalade kidd,
    I apologize for the reduced engine power you experienced while on the highway. I am glad you were able to work with a dealer towards fixing this concern. If you would like to further discuss your situation or have questions, please send me a private message. I am more than happy to assist.
    Kindest Regards,
    Laura M.
    Cadillac Customer Care
    MRANT212's Avatar
    Nov 2005
    55
    405
    Cadillac Tech, thanks for the info! Made it to the dealer this morning and the check engine light remained on. They didn't get a chance to get it in to look at it today as they were backed. At least they give me a loaner...2014 SRX. I'm curious to see what they find. At least a code will pop up.
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    48
    11,051
    You are most welcome, the codes will stay stored even if the light is off so they should be able to retrieve something.
    Codes stay in history until the tests run and pass 40 consecutive times with no failures.
    Oct 2013
    28
    268
    I'm almost sure one of the codes if only 1 will be p0011.
    Keep us updated.
    MRANT212's Avatar
    Nov 2005
    55
    405
    Didn't ask for the codes but they did say the throttle body has to be replaced. May have it back on Tuesday it looks like. Waiting up on some parts. I'll just rack up the mileage on the SRX loaner. Already put over 300 miles on it. the dealer I work with is Gold Coast Cadillac in NJ. Been dealing with them for many years and they've done right by me. Just hope this takes care of it....may get a 2015 Escalade when it comes out.
    Mar 2010
    Detroit, USA
    12,683
    Quote Originally Posted by MRANT212 View Post
    Hello MRANT212,
    Thanks for keeping us updated with your vehicle. We will definitely look for your future updates on Tuesday when you receive your vehicle back. I hope you are enjoying the SRX loaner that you were provided. I look forward to your updates.
    Gregory W.
    Jan 2014
    5
    Just got my truck back after a week at the dealership. Replaced the whole engine harness wiring(looked like a spagetti factory of wiring),mega fuse? and a curuit breaker? Hopefully this takes care of this shit show. Im really nervous about this issue! i need to stop reading all these horror stories online about this particular problem! Good luck to all in Cadillac Nation!
    MRANT212's Avatar
    Nov 2005
    55
    405
    Got mine back today...so far so good. They changed the throttle body, an oil sensor and also my battery was weak. I wish GM would recognize this is an issue and cover something on this. Anyway I may be purchasing a 2015 when it comes out....whoever buys my 07 will be getting one hellava truck!
    Rustico likes this.
  16. #14
    Mar 2010
    Detroit, USA
    12,683
    Quote Originally Posted by themunsta View Post
    Hello themunsta,
    I am glad to hear that the dealership was able to address the concern you were experiencing. Thank you very much for taking the time to post your experience. Please feel free to reach out to me via private message or email at socialmedia@gm.com with “ATTN GREG” in the subject line if you have any future questions or concerns.
    Gregory W.
    Hello MRANT212,
    I am happy to hear that you were able to receive your vehicle back today and that they addressed your concern you were experiencing. I will definitely document your feedback regarding this. Please let me know if there is any assistance I can provide with any future questions or concerns and please keep us updated when you purchase your 2015 model!
    Gregory W.
  17. #15
    Oct 2013
    28
    268
    same identical thing was done to mine including buying a new battery plus other parts. 3 weeks later... I got the same problem including "shut engine off, low oil pressure" message... brought it back into the dealer & the entire engine block was removed and camshaft bearings replaced at their expense.
  18. Remove Advertisements
