07 escalade lift up question
Results 1 to 15 of 15
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, 07 escalade lift up question in Cadillac Escalade Forums; Hello!Please who knows and who lift up his EXT 07-up.question is about suspension with electric absorbers.I saw many lift kits ...
    Ludvig is offline Cadillac Owners Member
    Automobile(s): escalade ext
    Oct 2013
    34
    4
    Hello!Please who knows and who lift up his EXT 07-up.question is about suspension with electric absorbers.I saw many lift kits on ebay, but it doesn't have any discription about diffirent types of it.I want to lift it but with factory ride quality.Plase let me know whi know all info of it or maybe articles in the web.
    bigwill1323704's Avatar
    bigwill1323704 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 EXT
    Oct 2012
    28
    181
    The issue I ran into when thinking about installing a lift the auto ride
    Some kits disable the
    While there are. Custom kits and shops that will keep it ridding like factory
    soulsea's Avatar
    soulsea is offline Cadillac Owners Enthusiast
    Automobile(s): 2016 Range Rover V8 SC ... 2015 Corvette Z06/Z07
    Nov 2012
    Mt Pleasant SC
    49
    923
    Re: 07 escalade lift up question
    Not sure how much you want to lift it and if you have 2WD or AWD ...
    If you just want to level the front (it's usually about 1.5" lower than the back), measure exactly what you need and you can buy something like this to achieve the leveling: http://www.readylift.com/products/ca...n-66-3090.html
    If you want to go higher, they also sell rear spring spacers ... I would just give them a call and tell them your exact model and what you want to achieve and they'll tell you what's possible, what you need, and how to do it. I'm sure there are other companies that sell lift components, but RL is pretty reputable so it's a good place to start.
    Be sure to ask them how to retain autoride and how to deal with the shocks, especially if you want to go higher than just a leveling kit.
    Oct 2013
    34
    4
    Hi! thnaks a lot.but how many inches " i can put...that doe's crack aout ride control system obsorbers.....and will it fails with higher lift kit nad will it be good for 1.5 lift fornt or rear i dont know how many, question is about lift and auto ride control system fail,maybe it can be disable but i thibk will be check engine light on and other problems.
    Oct 2012
    28
    181
    So do you want suspension lift. Of a level
    Leveled
    Vs
    Lifted
    soulsea's Avatar
    Nov 2012
    Mt Pleasant SC
    49
    923
    That second truck has a serious lift ... I believe the only way that's possible is by ditching the entire autoride system (trick the BCM with resistors) and revert to a true passive suspension lift kit.
    Why anyone would do this to an Escalade instead of an Avalanche is a bit beyond me since the Avy would cut the work/expense in half and has a more rugged look to begin with, and especially since the Avy is 4WD, but to each their own.
    Oct 2012
    28
    181
    Yea the price to do a seriously lift was around 4000 for the kit and install
    Oct 2013
    34
    4
    I want "Leveled" on first picture looks awesome with vendor flares!But want's with auto ride will be?
    soulsea's Avatar
    Nov 2012
    Mt Pleasant SC
    49
    923
    Okay so I spoke to a buddy who is running a leveling kit on his Avalanche LTZ, which I'm pretty sure has the same setup as an 07 EXT.
    This is what he has up front (which says it is compatible with Cadillac Pickup): http://www.topguncustomz.com/p-6484-...t-spacers.aspx
    And these are the spacers for the rear: http://www.ebay.com/itm/01-14-GM-Ful...210295&vxp=mtr
    And this is how his truck sits:
    Oct 2012
    28
    181
    That is my escalade In the pic pm me with your number if you want more info
    I have 2.5" In the front and 1.5"I the rear
    My level kit cost around 100.00. Installation will. Be the most if you don't do it your self
    It does not effect the auto ride, you don't need shock extenders
    hardkore-v is offline Cadillac Owners Member
    Automobile(s): CTS-V
    Jan 2012
    29
    26
    ^^^Listen to these guys. If you want minimal lift such as a leveling kit, I do not think that it would mess with the auto ride at all.
    I am currently in the process of lifting my EXT.. I have a 2010 and I am lifting it 8" on 20x12's and 35x12.50's.. The 8" lift is just spacers, drop downs, and extenders and utilizes the factory auto ride parts. It also requires a new CV driveshaft which is a Caddy only thing and an additional $475. I am going to be starting a thread in the project section shortly.
    Skyjacker makes a 3.5" kit. They sell for around $2500 around here plus labor, etc. To me, that's an insanely overpriced set up for what it is.
    Anyway you choose to do it, GOOD LUCK and ENJOY!!! I love looking at Escalades lowered on 24's but I wanted to be different. Lifted Escalades are few and far between probably mostly due to the fact they are a luxury SUV and everybody has different needs.. My wife is more than alright driving a lifted Caddy on 35's.. Plus the kids just think it's awesome.
    by the way, that Avalanche is gorgeous
    Oct 2012
    28
    181
    When you plan to do that I've always wanted 35 on mine
    Oct 2013
    34
    4
    Hi!How many inches " of lift will be good with auto ride cuz it's very sirous thing i think.
  16. #14
    soulsea's Avatar
    Nov 2012
    Mt Pleasant SC
    49
    923
    Just saw this parked outside my building:
  17. #15
    Jan 2012
    29
    26
    Quote Originally Posted by soulsea View Post
    that thing is super clean. 12" lift on 24's? for some reason those wheels just look big to me. could be 22's though
  18. Remove Advertisements
