Results 1 to 11 of 11
Thread: Help driver side mirror won't fold in!******
    Leamonzgirl is offline Cadillac Owners Member
    Automobile(s): Escalade 2007
    Oct 2013
    3
    I tried to fold my automatic windows in but for some reason the driver side won't fold in. The passenger fine is fine. When I push the button, I can hear the motor on the inside.
    I tried to give it a little tug without using too much force and now I can rock it a little with my hand which I wasn't able to do before. What can I do? Is this going to cost a fortune at the dealer? I am not handy"
    Suicidalbob is offline Cadillac Owners Member
    Automobile(s): 2007 Escalade ESV
    Sep 2013
    Michigan
    35
    Hearing the motor eliminates any fuse issue, which is easy to fix. If you're not handy, you're probably looking at a dealership visit.
    JCat27 is offline Cadillac Owners Member
    Feb 2013
    36
    16
    Re: Help driver side mirror won't fold in!******
    Look on ebay for a used one that folds. I got a deal on a new one from a buddy of mine, but its going to cost you $300+ for the mirror alone.
    Dealership is going to charge $600+ for the mirror and prob $150ish to put it in.
    Its super easy to replace, just did mine last month and it took 15 minutes. Pull the cover, unscrew the mirror, unscrew and pull off the door panel, unplug wires from door panel and replace. Im sure there is a DIY out there.
  5. #4
    Oct 2013
    3
    Ok. I need help trying to find one...I have the one with the chrome finish at the bottom of the mirror...can someone help me out with searching on ebay? They seem to not have the chrome. I believe the part number is 25831064
  6. #5
    greenapple is offline Cadillac Owners Member
    Automobile(s): 2009 Escalade
    Feb 2008
    Texas
    33
    Quote Originally Posted by Leamonzgirl View Post
    What color?
  7. #6
    Oct 2013
    3
    Black...how much do u think it might be if I got it painted? Couldn't find black
  8. #7
    Aerocoupe is offline Cadillac Owners Member
    Automobile(s): NONE
    Aug 2011
    Tulsa, OK
    45
    70
    My DS mirror finally bit the dust and I need to know what years will interchange. I have a 2007 and would really rather get as new of a used one as I can so it has less wear and tear.
    Thanks and sorry for the hijack,
    Darren
  9. #8
    AZKlaus is offline Cadillac Owners Fanatic
    Automobile(s): 2010 Escalade EXT Premium
    Jun 2013
    418
    I have a similar question on interchange- will the 2010+ mirrors connect or is it a different harness due to blindspot and lane departure integration?
    Aerocoupe the 2007-2009 mirrors are all the same
  10. #9
    Automobile(s): NONE
    Aug 2011
    Tulsa, OK
    45
    70
    I am not worried about the wiring harness as that can be made to work. My question is about fit and finish with regards to the 2010+ mirror housing bolting up to the door and the existing trim lining up. Hopefully that makes sense.
    Darren
  11. #10
    Jun 2013
    418
    Quote Originally Posted by Aerocoupe View Post
    Darren
    Hmm hadn't even considered that they might change the housing design... makes total sense. The only thing I can tell visually is a different turn signal LED setup- maybe I'm wrong here but unless they changed the doors and door trim the mirrors have to be the same as well. But of course assuming doesn't usually work out for the best!
  12. #11
    Sep 2014
    1
    I also have passenger side mirror that will not fold in or out, and I cannot hear the motor run. You said it was an easy fix, but I cannot find where the fuse or circuit breaker for is located. Can you help me out? Thanks,
    Ron
  • You may not post replies
