Tire size on 24s
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, Tire size on 24s in Cadillac Escalade Forums; Whats the largest tire size you can go on 24s? The more aspect ratio the better for ride purposes. J...
    jkinder33 is offline Cadillac Owners Member
    Automobile(s): 2008 escalade
    Sep 2013
    51
    Tire size on 24s
    J
    ELUSIVE is offline Cadillac Owners Enthusiast
    Automobile(s): Porsche Cayenne Diesel, Porsche 997 Carrera S, VW Passat SE
    Nov 2010
    Colorado, USA
    42
    595
    Re: Tire size on 24s
    I have 305/35/24. I would not use this size again, although I really like the Pirelli Scorpion tires.
    I would go 295/35/24 if I had to do it again.
    ridesguy is online now Cadillac Owners Member
    Automobile(s): 2007 Escalade ESV, 2010 CTS v
    Jul 2011
    Orlando
    58
    I have 305 too and they look and ride great, tires are Nexen. Curious why you don't like them? No turning issues or board issues.
    soulsea's Avatar
    soulsea is offline Cadillac Owners Enthusiast
    Automobile(s): 2016 Range Rover V8 SC ... 2015 Corvette Z06/Z07
    Nov 2012
    Mt Pleasant SC
    49
    923
    Mmm, even 295/35s will rub a tiny bit on the liners at full lock ... hard to believe that anyone can run 305/35s without serious rub.
    ELUSIVE has pics of how much 305/35s rub on one of his threads.
    Sep 2013
    51
    I currently have 26 x 9.5 wheels with 305/30r26. Those tires are taller and just as wide so they must rub. I just bought the truck though. I want to downsize to 24s and get the biggest tires for ride purposes.
    @soulsea your lowering kit doesnt contribute to the rubbing? Is it more of a front to back issue than height of truck issue.
    soulsea's Avatar
    Nov 2012
    Mt Pleasant SC
    49
    923
    It probably contributes a tiny bit. I had two remove two little plastic tabs that hold the liner cause they were rubbing, but now only a tiny bit backing up at full lock.
    Sep 2013
    51
    I check my tires on the 26s. The rears have a wearing on the inside part of the tire. Looks like something with rubbing against the tire. I bet the rears used to be on the front and got rotated.
    What about the 295/40r24? I do not have power running boards. How is that size different? taller but not as wide as the 305/35/24 or little bit more side wall vs the 295/35/24
    soulsea's Avatar
    Nov 2012
    Mt Pleasant SC
    49
    923
    Here: http://www.rimsntires.com/specs.jsp
    Start with 295/35/24 x 10" width and 30 ET (offset) cause you know that's the max before you start serious rubbing ... then you can play with alternate tire sizes to see what is smaller and bigger.
    Sep 2013
    51
    When comparing the 295/35/24 to my current 305/30/26 the current tire is 1 taller in diameter and .5 wider. Ill have to go inspect for signs of rubbing because that alot bigger. thanks soul sea
    The 305/30/26 don't ever touch when i turn wheel left to right. You can see where there has been some rubbing in the plastic. THe guy had been running these 26s for 3 years so the rubbing is minimal. Thats interesting because the tires are much bigger than 295/35/24. Maybe the 30s has a sharper profile sidewall and doesn't balloon out much. Maybe it has something to do with offset.
    Has anyone tried 285/40/24s? Read on another forum people like those. You lose the wide squatty look but gain side wall.
    Noob is offline Cadillac Owners Member
    Nov 2010
    71
    I have 305/35/24 and absolutely love it. I don't notice any rubbing, though I know on RARE occasions it'll lightly rub small parts of the inner liner. I didn't feel it, and only reason i know is there's a small "shiny" spot on the plastic. But I'll gladly take that so I can have a little extra cushion and curb protection from the crappy roads.
    soulsea's Avatar
    Nov 2012
    Mt Pleasant SC
    49
    923
    Guys, unless you state what your wheel offset is, then it's going to be hard to compare on just tire size alone.
    305/35 rubs quite a bit on an OE 30 offset with or without a drop (with a drop you have to start cutting a lot of liner), many many people have documented this with 24" OE replica wheels that have the 30 offset.
    Sep 2013
    51
    Currently i have 26 x 9.5 wheels with 305/30r26 - wheel offset +25. Overall tire size is 33.2 x 12. It seems to run fine. Im going to down size to 24" ck375 wheels 24 x 10. I dont know offset. Id like to put as much tire on as possible. Seems like options are 295/35r24, 305/35r24 or possibly 285/40r24. Id like to possibly do the 285/40r24 but dont know if thatll work with 24 x 10 rims. Seems like height and width (33 x 11.2)is no problem because its smaller than what i have now although you lose the wide sqautty look. Thanks for your input
    soulsea's Avatar
    Nov 2012
    Mt Pleasant SC
    49
    923
    Okay so you're looking at the same rims I have.
    They have exactly the same offset (30) as the 24" rims ELUSIVE runs, and this is the rub on his truck (stock height) with 305/35:
    Keep in mind that's with the truck parked ... when it's turning and pitching side to side and front to back it gets more noticeable.
    That's why I run 295/35.
  16. #14
    Nov 2010
    Colorado, USA
    42
    595
    Quote Originally Posted by soulsea View Post
    Completely agree.
    And precisely the reason why I wish that i would have gone 295/35 instead of 305/35. I also had to slide my automatic steps back a bit as the tires were rubbing on them as well.
    And I just put my 22's back on and BOY OH BOY does it drive nicer.
  17. #15
    Nov 2010
    71
    Well for reference, I have a 2010 rwd escalade, base model with fixed step rails and stock height. 305/35/24 nexxen roadians on the esky replicas from Cpw wheels. Minor rubbing. I actually don't even know when it rubs, only evidence is a smooth spot in the front section if the fender well. Size about a baseball. I turned the wheel to full lock and it seems like it's literally 2mm away. So only time I think it rubs is full lock going up or Down a curb.
  18. Remove Advertisements
