DIC oil change interval with new oil
Results 1 to 5 of 5
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, DIC oil change interval with new oil in Cadillac Escalade Forums; I have always used the regular mobile one synthetic oil because the manual calls for it. I understand the ECU ...
    alex29573 is offline Cadillac Owners Member
    Automobile(s): 2008 Escalade
    Sep 2012
    30
    26
    I have always used the regular mobile one synthetic oil because the manual calls for it. I understand the ECU is programmed for a certain number of revolutions depending on engine temperature and whatever other variables - before it goes from 100% to 0% engine oil life using this specific oil
    If I start to use the mobile one extended life oil, Am I supposed to ignore the DIC and change oil at 15,000 miles?
    Or will the ECU somehow pick up that I am using better oil and then give me more miles for the cycle of 100% to 0%??
    2kflhr's Avatar
    2kflhr is offline Cadillac Owners Enthusiast
    Automobile(s): '10 Escalade, '97 Eldo ETC (Z)
    Dec 2004
    Mooresville, NC
    58
    897
    Re: DIC oil change interval with new oil
    I won't attempt to answer your question but I must ask this question.
    Would you be planning to change the oil filter during that 15k mile oil change interval?
    I would personally never attempt to go 15k on the same oil even if having an oil and engine wear analysis every 5k.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    The OLM calculates oil life based on a number of things (RPM, temp, run time, mileage...), it does not sample the oil. So no, it won't adjust to different oils.
    I believe GMs MAX change interval is the same for your car as it is for mine, 10K miles or 12 months, check your owners manual. Honestly, if you're already using a synthetic, there won't be any advantage to switching to a "better" (more expensive) one.
    Sep 2012
    30
    26
    I would use the mobil 1 extended life oil filter that is supposed to be rated for 15k
    I would honestly run it up to 10k which for the extra $5 it would cost, would be worth it (6kmiles vs 10kmiles)
    gdirty5 is offline Cadillac Owners Member
    Automobile(s): cts
    Oct 2009
    93
    I change mine every 6-8k miles. But I drive pretty hard, and change my own oil... Currently using royal purple, but for the first year and a half I was using mobil1. I don't know if the RP is worth the extra money, but I got a crazy deal on some and bought about 60 quarts and about 12 filters. Currently use it in all of my vehicles.
  8. Remove Advertisements
