Map DVD Read Error
Results 1 to 8 of 8
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, Map DVD Read Error in Cadillac Escalade Forums; The navigation on My 2008 Escalade EXT says Map DVD Read Error. Does anyone have the same problem or a ...
    gm 78 is offline Cadillac Owners Member
    Automobile(s): 2008 Escalade EXT
    Sep 2013
    1
    Map DVD Read Error
    The navigation on My 2008 Escalade EXT says Map DVD Read Error. Does anyone have the same problem or a solution.
    Thanks,
    Greg
    dzar is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Cadillac Escalade ESV
    Aug 2007
    211
    Same problem on my 2007 ESV. First, try cleaning the map DVD. That worked for me a couple of times, but the DVD player eventually simply died our list its calibration and would not read any map disk. To fix that, I found a used player on eBay and swapped it in. Works great, now.
    You can also swap the entire center console, which is easier but much more expensive.
    If you want to know more about swapping the drive only, let me know.
    Sent from AutoGuide.com Free App
    juanlo1211 is offline Cadillac Owners Member
    Automobile(s): escalade 2008 6.2ltr
    Oct 2013
    34
    4
    Re: Map DVD Read Error
    i have the same problem
    bagbklyn is offline Cadillac Owners Member
    Automobile(s): Cadillac Escalade ESV
    Apr 2010
    Queens, NY
    59
    Your best option might be to look on ebay for a new DVD.
    Suicidalbob is offline Cadillac Owners Member
    Automobile(s): 2007 Escalade ESV
    Sep 2013
    Michigan
    35
    Same problem on a 2007. Replaced with a new unit @ $800.
    wesyder's Avatar
    wesyder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
    Mar 2009
    Eastvale Calif
    1,796
    Quote Originally Posted by Suicidalbob
    or send here and get it repaired oemautopartsco.com
    Aug 2007
    211
    You can replace only the dvd with a bit of time... check eBay for a teardown and save over $500. Just another option.
    Sik Six is offline Cadillac Owners Member
    Automobile(s): Escalade
    Nov 2012
    1
    Does anyone know the part number to replace the DVD mechanism In 2008 escalade? I am getting this same error.
  11. Remove Advertisements
