2007 escalade 15A fuse blows for rear entertainment system
Results 1 to 2 of 2
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, 2007 escalade 15A fuse blows for rear entertainment system in Cadillac Escalade Forums; The problem is the rear screen on the rear entertainment system will not show any dvd that we play. It ...
    jergen is offline Cadillac Owners Member
    Automobile(s): 2007 Escalade
    Aug 2013
    1
    The problem is the rear screen on the rear entertainment system will not show any dvd that we play. It is a factory installed system. I checked the 15 amp fuse under the hood and found that the fuse was blown. When I put a new 15 amp fuse in, the fuse blows immediately when I put it into the fuse block. I can put a 20 amp fuse in its place and the 20 amp fuse will not blow but it is hot to the touch when I pull it out of the fuse block and the rear entertainment system still does not work with the 20 amp fuse in. Any suggestions?
    kazza93203's Avatar
    kazza93203 is offline Cadillac Owners Fanatic
    Automobile(s): 07 Escalade
    Aug 2011
    30
    190
    Quote Originally Posted by jergen
    Take that 20 amp fuse OUT! Lol unless you want a fire on your underhood fuse block. There is a short to ground causing that fuse to blow. Just not big enough to blow a 20 amp fuse. Check your wiring.
