MAF P0102 in Aftermarket Intake.
Results 1 to 2 of 2
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, MAF P0102 in Aftermarket Intake. in Cadillac Escalade Forums; I wrecked my old Escalade (2004 ESV), and Salvaged the INJEN intake from it, and I noticed that I could ...
    Phasmaphobia is offline Cadillac Owners Member
    Automobile(s): 2004 Cadillac Escalade ESV, 1979 Chevrolet Camaro Z28
    Aug 2013
    I wrecked my old Escalade (2004 ESV), and Salvaged the INJEN intake from it, and I noticed that I could just slip it on and replace the stock one my 2007 ESV had. I swapped it out and I put a Breather Filter on the little pipe coming out of the Head (it was plugged into the stock intake, but the 04 intake didnt have a place to insert it at). I placed the MAF Sensor where the old stock MAF Sensor was in the 04 Intake. It drove fine for a couple of days, when suddenly, Traction and Stabilitrak are disabled randomly. I restarted my truck then I notice the Engine Light comes on. Error Codes: C0561, P0102, P0121, P0171, P0174, and P0172 appear. There is a sensor in the front driver caliper (I was told a speed sensor) that was throwing a Code, and also the other codes were showing that the Truck was running Lean, and the MAF Sensor was experiencing an Error. I am putting my Stock intake back on for the time being. Hopefully the codes clear! But any suggestions? As to the MAF Sensor being bad?
    wesyder's Avatar
    wesyder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
    Mar 2009
    Eastvale Calif
    1,802
    Quote Originally Posted by Phasmaphobia
    Keep me posted i gotta 03 and im fighting a p0102 as well, i already swapped the MAF and PCM with a known good one i also traced and tested the wiring to no avail, going after a possible intake leak and fuel pressure test next
