Drivers Side window won't go down
Results 1 to 2 of 2
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, Drivers Side window won't go down in Cadillac Escalade Forums; Recently my driver side power window won't work. Then out of the blue it worked one day and since has ...
    Mrs G is offline Cadillac Owners Member
    Automobile(s): 2011 Escalade Platinum
    Aug 2013
    1
    Recently my driver side power window won't work. Then out of the blue it worked one day and since has ceased to operate. Does anyone know if this is just a loose wire or if it's a common issue?
    Also, my sunroof is leaking while I'm in the car wash! Just a few splashes coming out but still not good if I should be in a downpour somewhere!
    thanks!
    anthonyj923 is offline Cadillac Owners Member
    Automobile(s): 2011 Escalade ESV Premium
    May 2013
    Re: Drivers Side window won't go down
    I have the same problem with my 2011 escalade ESV drivers window. Sometimes it works, most of the time it doesn't. All the rest of the windows work from the drivers position.
