Cadillac escalade 07 rear ac problem
Results 1 to 6 of 6
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, Cadillac escalade 07 rear ac problem in Cadillac Escalade Forums; Cadillac Escalade 07 rear ac start giving off heat. Top rear don't work unless you put the rear back on ...
    gtkavien is offline Cadillac Owners Member
    Aug 2013
    3
    Cadillac Escalade 07 rear ac start giving off heat. Top rear don't work unless you put the rear back on an put it to 90 then the back bottom comes off. When I put it back to 60 the the rear top comes off then the back bottom only comes on but hot air only. I gas the ac the rear a
    I gas the ac but the rear only got cold for 5 min then returned back to heat. The front works find. What should I do.
    My rear ac not working good at all. The rear bottom comes on at 60F and hot air only comes out. When I turn up the heat from the back to 90 then the rear top comes on an the rear bottom stopes. Hot air only from rear need help on what to do.
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,697
    Re: Rear ac problems
    Quote Originally Posted by gtkavien View Post
    Hello gtkavien,
    I apologize your Escalade is experiencing an HVAC malfunction. I would like to look into this concern for you and explore our options for a resolution. Please reach out via private message and include your contact information, VIN and current mileage.
    Sincerely,
    Laura M.
    Cadillac Customer Care
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Sounds like the control box has gone nutty
    Aug 2013
    3
    Quote Originally Posted by Cadillac Cust Svc
    Hello gtkavien, I apologize your Escalade is experiencing an HVAC malfunction. I would like to look into this concern for you and explore our options for a resolution. Please reach out via private message and include your contact information, VIN and current mileage. Sincerely, Laura M. Cadillac Customer Care
    What would be the best solution ?....
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,569
    Unless you have GM warranty problems or dealership service complaints, "Customer Care" is the wrong forum for routine care and maintenance advice. Please read the descriptive text in each forum banner to find out what's supposed to be posted there.
    Moved to the proper Escalade forums.
    from yet another thread: Please stop triple posting - let ONE thread, posted in the proper forum, do your work.
    Mar 2010
    Detroit, USA
    12,697
    Re: Cadillac escalade 07 rear ac problem
    Hello gtkavien,
    If you reach out via private message and include your VIN, I can check to see if anything is associated with your vehicle.
    Laura M.
  9. Remove Advertisements
