P0121 code on a 2007 escalade
Results 1 to 5 of 5
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, P0121 code on a 2007 escalade in Cadillac Escalade Forums; I'm stuck in Virginia, I live in ny.. My check engine light came on , took it to auto zone ...
    mooksta12 is offline Cadillac Owners Member
    May 2013
    8
    I'm stuck in Virginia, I live in ny.. My check engine light came on , took it to auto zone , P0121 was the code.. Autozone does not have the part but advanced auto telling me I need a whole new throttle body.. Is this true?? Can some1 help me please..
    roadog1aj is offline Cadillac Owners Fanatic
    Automobile(s): 2011 EXT Premium & 2006 STS4
    Jun 2009
    North East Ohio
    212
    Re: P0121 code on a 2007 escalade
    It could be the "Throttle Actuator" is popping the code. From everything I've seen, the 2007 does not have a Throttle Position Sensor, which would be the normal train of thinking. First thing I would try, if it were me, is to take the air intake cover off of the throttle body, and spray some good throttle body cleaner inside, making sure you hit the sensor areas to remove all the carbon built up inside. This may very well take care of the problem, and save you quite a few clams to boot. It might take a few cycles to clear the code, so you could either take it back to Auto Zone and have them clear it, disconnect your battery for about 10 minutes, or just drive it and see if it clears itself over time.
    wesyder's Avatar
    wesyder is online now Cadillac Owners Connoisseur
    Automobile(s): 08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
    Mar 2009
    Eastvale Calif
    1,814
    Quote Originally Posted by mooksta12
    Ive seen this before on a few other trucks and the throttle body was changed to resolve
    gtkavien is offline Cadillac Owners Member
    Aug 2013
    3
    I have the same problem they told me to clean the throttle body or get a new one to solve the problem.
    blackex is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Cadillac Escalade Base
    Aug 2010
    Troy, Michigan
    32
    380
    Cleaning the TB is fairly straight forward and simple. If you have carb cleaner, some tools and some free time it's pretty simple. Otherwise a new TB is around $80 I believe on Rockauto.
  8. Remove Advertisements
