Random Blue Smoke at startup
Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By the blur
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, Random Blue Smoke at startup in Cadillac Escalade Forums; I get a plume of blue smoke at startup sometimes. Not often but it happens and I dont like it. ...
    cudaz101 is offline Cadillac Owners Member
    Automobile(s): Escalade
    Sep 2012
    12
    I get a plume of blue smoke at startup sometimes. Not often but it happens and I dont like it. Wondering if anyone else has had the same thing. It doesnt burn oil, just made a 800mile trip last weekend and the oil level stayed the same.
    Ive not seen it smoke during driving, only at random startup. Fuel mileage and general performance is great as well.
    Thanks in advance!!
    Brad
    MrHolland's Avatar
    MrHolland is offline Super Moderator
    Automobile(s): 2010 Platinum Escalade, 1996 Fleetwood Brougham
    Jul 2010
    Midwest
    5,658
    Re: Random Blue Smoke at startup
    What year is your car???
    wesyder's Avatar
    wesyder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
    Mar 2009
    Eastvale Calif
    1,802
    Quote Originally Posted by cudaz101
    Thanks in advance!!
    Brad
    Possible intermittent leaking injector maybe try a pour in the tank fuel system cleaner
    the blur's Avatar
    the blur is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac
    Oct 2008
    NY
    1,016
    Blue is oil. leaking injectors (fuel) is black. You probably need valve seals, which will only blow oil when the motor is COLD.
    K9Caddy likes this.
    AZKlaus is offline Cadillac Owners Fanatic
    Automobile(s): 2010 Escalade EXT Premium
    Jun 2013
    407
    Correct on the valve stem seals. If the seals are on their way out after the car cools down the seals will contract dripping just a few drops of oil into the combustion chamber and then when you start the car that oil will burn. At that point the seal will re-expand and "plug" the leak. I'm actually surprised your running into this, GM's 06+ v8s use very strong valve seal material, I'm curious how many miles you have?
    As for what to do about it. A well built motor can potentially go another 50k on seeping valve seals. It's when you start getting blue puffs when the motor is warm that you really have to worry as that point the seals are no longer reswelling enough to seal the combustion chamber and you'll run into all sorts of issues including low compression. Again it can be as long as another 50k before this happens. But I would certainly address it sooner than that. Get some estimates on replacing them and do it when you're ready sometime within the year. Good luck!
    the blur's Avatar
    Oct 2008
    NY
    1,016
    Me personally, I'd never replace them, as a morning puff of blue does nothing. All my 1980's era Chevy's did it, and it still puffs blue till this very day. 100,000 miles later, it's no worse.
    Jun 2013
    407
    Quote Originally Posted by the blur View Post
    Valid point, and the valve material then wasn't nearly as durable as they are now. My 94 Supra's original engine had it for about 40k miles before it starting getting worse and I eventually started losing compression and blue puffs while driving so for that and other reasons I rebuilt it with Viton valve seals and I expect those to last the duration even with very high cylinder pressures from the turbocharged application.
    The L92 in your truck is a 10.5:1 compression so is a higher performance application and will wear down a seeping seal faster than a commuter engine. But absolutely, you can wait until you actually see some adverse effects before you do anything about it, most likely it's going to be a while
    the blur's Avatar
    Oct 2008
    NY
    1,016
    Quote Originally Posted by AZKlaus View Post
    You'll never loose compression from a bad valve seal.
    Sep 2012
    12
    Thanks for the feedback guys. I should have given more information to glean from.
    2007 with 105K on it. It runs great, doesnt require adding oil between changes (3Kmi.). Fuel mpg is at 19mpg hwy and 14city.
    Jun 2013
    407
    When the valve seals go to the point of causing burned valves yes they absolutely can
    Quote Originally Posted by cudaz101 View Post
    Yeah we're really talking about a tiny amount of oil, maybe a couple tablespoons between changes if that so nothing that would be really noticeable. Just keep an eye on it, you'll be in good shape!
    K9Caddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 AWD Escalade Ultra Luxury Raven Black
    Oct 2009
    Illinois
    38
    1,478
    Are you talking about the intake or exhaust valve seats in the combustion chamber? Quite different than the valve seals that are located under the valve covers in the upper head.
    Jun 2013
    407
    Quote Originally Posted by K9Caddy View Post
    No not the seats, the valve stem seals that prevent oil from leaking into the intake/exhaust ports
    the blur's Avatar
    Oct 2008
    NY
    1,016
    A little bit of oil acts as a pre-lubricant, so it actually extends the life of your engine.
  16. #14
    Nice Ride is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 ESV Platinum / 2013 SRX Premium
    Jan 2012
    1,251
    What oil are you using? Just curious...
  17. #15
    hollingass is offline Cadillac Owners Member
    Automobile(s): 2008 ESV ultra luxury
    Oct 2012
    65
    The valve stem seals NEVER have to deal with combustion chamber pressures during the compression stroke, that is the purpose of the actual valve and seat, those seals just prevent excess oil from seeping down the valve stem and ultimately into the combustion chamber when the valve is open, it is almost certain there will be a few valves open even when the engine is shut off.
    So no, the partial or complete failure of valve stem seals will not cause a loss of compression
  18. Remove Advertisements
