Which oil to use for a oil change on a 2008 Escalade?
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 27
Like Tree2Likes
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, Which oil to use for a oil change on a 2008 Escalade? in Cadillac Escalade Forums; Just bought a 2008 Escalade and was looking around to find the best price for an oil change. Need to ...
    Bengal313's Avatar
    Bengal313 is offline Cadillac Owners Member
    Automobile(s): 2008 Cadillac Escalade Black Ravon Utra Luxury Package
    Jul 2013
    32
    Just bought a 2008 Escalade and was looking around to find the best price for an oil change. Need to know what kind of oil i should use. There is a dramatic price difference between synthetic and regular. What should be used with this truck? I looked on the cap and it say "SAE 5W-30".
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    Re: Which oil to use for a oil change on a 2008 Escalade?
    your owners manual will tell the full story but the cliff-notes version is that any "starburst" labeled 5w30 will do
    Rich08's Avatar
    Rich08 is offline Cadillac Owners Fanatic
    Automobile(s): 2008 Escalade EXT
    Feb 2013
    Jersey
    146
    Mobil 1 synthetic 5w-30 and a ac delco pf48 oil filter. You need 6 quarts, Walmart has the best price for oil. The whole thing will run you about 35$ to 40$ I change it my oil every 3k miles
    MrHolland and JoeWalsh185 like this.
    Bengal313's Avatar
    Jul 2013
    32
    From what I understand the cap say to use regular, "SAE 5W-30". But someone told me to use "Dexo". Some sort of semi-synthetic. The truck as 70k. Should I start using synthetic, semi-synthetic or stick with regular? Using these more expensive oil, is it worth it? Should I do it?
    Sep 2007
    Wilmington, NC
    13,986
    there is no reason to use semi syn, full syn or anything more than plain conventional oil
    your Oil Life Monitor is calibrated for conventional oil and any better oil that you use will still have way more life left to it than the OLM says it does so you'll basically be wasting money (and precious natural resources) on the better and more expensive oils
    Bengal313's Avatar
    Jul 2013
    32
    Also I heard that the synthetic oils are thinner and has a better chance of sipping through the gaskets on older cars. Is that true? I guess I will stick to regular and change it religiously every time the warning pops up. TY
    blackex is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Cadillac Escalade Base
    Aug 2010
    Troy, Michigan
    31
    380
    Thats a myth. It's actually not easy to find conventional oil anymore since most of them are partially blended and mixed with synthetics now anyways.
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2012 Escalade, 2014 SRX
    Apr 2003
    H.V., Pa/Town of Webb, NY
    13,280
    They come from the factory with full synthetic oils everywhere on the truck, use at least Mobil 1 or better.
    Damndirtyape is offline Cadillac Owners Member
    Automobile(s): 07 Escalade EXT
    Jul 2012
    92
    All the boutique oils always compare themselves to Mobil 1 synthetic. So guess what I use. Seems to be the standard, available everywhere, including at wally world where it's (relatively) cheap.
    Bengal313's Avatar
    Jul 2013
    32
    Mines a 2008. I thought it came with regular. There is nothing on the cap to say it's synthetic. I just don't want to spend $70 on a oil change when I can get the regular for $25. What are the benefits of synthetic to justify the cost? I plan on changing the oil on a timely basis.
    Sep 2007
    Wilmington, NC
    13,986
    It came from the factory with conventional oil ... again, read the owner's manual
    if you don't have one they are available online in PDF form ... if you can't find it i'll get you a link
    i can even pull up the relevant page for you and post it here if you want
    adamjeeps is offline Cadillac Owners Connoisseur
    Automobile(s): 2012 SRX Performance FWD
    Oct 2007
    1,497
    Quote Originally Posted by Rich08 View Post
    The pf-63 can be used, many on bob is the oil guy say it is preferable due to its larger filter media and slightly larger capacity. It is the same as the pf-48 only about 22mm longer.
    Sep 2007
    Wilmington, NC
    13,986
    plus it's easier to grab ahold of when you're installing and removing it ... we still use the PF48 though
  16. #14
    Bengal313's Avatar
    Jul 2013
    32
    The cap says nothing about synthetic but I pulled up the manual online and on page 5-16
    "Your vehicle’s engine is filled at the factory with a
    Mobil 1® synthetic oil, which meets all requirements for
    your vehicle."
    http://www.cadillac.com/content/dam/...esv_owners.pdf
  17. #15
    Sep 2007
    Wilmington, NC
    13,986
    i stand corrected
    i thought 2009 was the first year the escalades switched to the Mobil1/GM4718M spec
    apparently it was 2008
    just double checked in my parts catalog and recommended fluids page for oil says Mobil1
    and the oil filler cap is a Dexos oil filler cap (the mobil1 advertising/cross-promotion deal ended in 2011 when Dexos came out)
  18. Remove Advertisements
