New Shock Install now alarms in dash????
Results 1 to 13 of 13
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, New Shock Install now alarms in dash???? in Cadillac Escalade Forums; Just installed 2 rear OEM replacement air shocks for my 07 Escalade.Everything went perfect..started up rig to back out of ...
    LABRADOR WARRIOR is offline Cadillac Owners Member
    Automobile(s): Escalade
    Feb 2010
    5
    Just installed 2 rear OEM replacement air shocks for my 07 Escalade.Everything went perfect..started up rig to back out of shop,,now I have 2 lights on in the dash ABS and traction control..WTF?? What could be causing this??. I hate to see a light on in a dash that doesn't belong there..
    any ideas?
    Thanks
    LW
    sdgc is offline Cadillac Owners Enthusiast
    Automobile(s): 2012 Escalade
    Sep 2012
    511
    Re: New Shock Install now alarms in dash WTF????
    Was there any wires you had to disconnect?
    Ran-Dom32 is offline Cadillac Owners Member
    Automobile(s): 2007 Escalade '08 CTS '06 H2
    Apr 2013
    41
    95
    check the top of frame rail... when you pulled out the upper shock bolts I bet you accidently unplugged the wheel sensor, the same thing happened to me *both sides* I freaked out
  5. #4
    Feb 2010
    5
    Did not see any wires unplugged but I'll double check again tomorrow
    Thanks
    the only wires I unplugged were the wires to top of the shocks
  6. #5
    AINTNOFORD's Avatar
    AINTNOFORD is offline Cadillac Owners Member
    Mar 2005
    Pensacola Fl
    26
    Drive around town for a few miles. If the lights don't go out, disconnect the neg cable for 15 to 20 mins as this will reset any codes stored. Had this happen when I changed the brakes on my 2005 EXT. When the vehicle is up in the air and the shocks fully extended, it stored those trouble codes.
  7. #6
    Feb 2010
    5
    Re: New Shock Install now alarms in dash????
    everything checked ok and there are no wires unplugged..also unhooked battery for 30 mins and the ABS and traction control lights/warnings are still on
    guess I have to get a dealer to hook up computer to tell me whats wrong??
    nearest dealer is 245km away (150 miles approx.)
  8. #7
    blackex is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Cadillac Escalade Base
    Aug 2010
    Troy, Michigan
    31
    380
    Try give it a drive around for a few miles and then turning it off and starting it back up. Had this happen to me and I didn't replace the rear shocks when the warning messages popped up. After driving around for a while and then turning it off after getting home the message eventually went away.
  9. #8
    Feb 2010
    5
    still the same
  10. #9
    Aug 2010
    Troy, Michigan
    31
    380
    What about going through the car wash? lol might work?
  11. #10
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,665
    Sorry to hear that you haven't been able to get the alarms cleared on your own and that your nearest dealer is so far away, Labrador. If you need additional support as you work with a dealership, GM of Canada is available to you at 1-888-446-2000.
    Regards,
    Sarah (Assisting Laura)
    Cadillac Customer Care
  12. #11
    Apr 2013
    41
    95
    I still think it's the harness above the frame rail, you can't see it, you have to reach up & feel around for the connection, near the upper shock bolts, squeeze & make sure they are tight on both sides
  13. #12
    Feb 2010
    5
    Man I love this site..found problem..Thanks so much Ran-Dom32..found one of the harness connections on the frame rail like you suggested wasn't pushed together properly
    My Escalade is alarm /warning light free
    thanks so much
  14. #13
    Apr 2013
    41
    95
    no problem , same thing happened to me... searched the net & came across a GMC forum & found the problem, it's such a relief when you can fix it yourself
  15. Remove Advertisements
