6.2 intake problem
Results 1 to 3 of 3
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, 6.2 intake problem in Cadillac Escalade Forums; I just installed a new afe cold air intake on my 2007 ext and now my check engine light came ...
    Kevin Dot is offline Cadillac Owners Member
    Jul 2013
    8
    6.2 intake problem
    I just installed a new afe cold air intake on my 2007 ext and now my check engine light came on no just wondering if anyone else had the same problem?
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2012 Escalade, 2014 SRX
    Apr 2003
    H.V., Pa/Town of Webb, NY
    13,280
    Re: 6.2 intake problem
    Our shop installs several a month and never had an issue, check that there is no debris on the MAF sensor, you may have got some sucked thru the intake filter, you using the 5411072 or the 5481072? Make sure you have good connection at the t-body too. Then disconnect the battery for 5 minutes, make sure your radio and hvac system is off before disconnecting the battery. Welcome to the forum.
    blackex is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Cadillac Escalade Base
    Aug 2010
    Troy, Michigan
    31
    380
    Did you forget to plug in your MAF after installation?
