Removing drop kit
Page 1 of 2 12 LastLast
Results 1 to 15 of 27
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, Removing drop kit in Cadillac Escalade Forums; I think I'm going to take out my McGaughys drop kit. I can't take the ride no more. I was ...
    BEarle is offline Cadillac Owners Enthusiast
    Automobile(s): 2010 Cadillac Escalade
    Dec 2011
    30
    671
    Removing drop kit
    I think I'm going to take out my McGaughys drop kit. I can't take the ride no more. I was trying to decide either go back to the 22s and keep the drop or keep the 24s and raise it back up and I decided to keep the 24s. It sucks because it looks so dam good with the drop but with the choppy ride I can't stand it anymore now the truck is starting to squeak and rattle and it drives really screwed up. My gf was even saying the other day what's wrong with the truck!
    Does the drop affect the ball joints or control arms at all? Or is that springs?
    firstlac27's Avatar
    firstlac27 is offline Cadillac Owners Member
    Jul 2013
    3
    Anytime you put big rims on a car or truck you are killing the suspension. Pretty sure your suspension is shot, you have to change some suspension parts in maybe take off the drop, Unless you like paying for suspension parts in labor, You can still ride good with just 20s
    Dec 2011
    30
    671
    Yeah I had friends of mine that swore by the spindle kit but it ain't cutting it for me. I just replaced the shocks not too long ago so they are new. I had the 24s on it before I lowered it and it drove nice.
    36dbldz's Avatar
    36dbldz is offline Cadillac Owners Fanatic
    Automobile(s): 2010 Escalade
    Sep 2012
    The Sunshine State
    308
    Quote Originally Posted by BEarle
    What's size tire did you use?
    emay's Avatar
    emay is offline Cadillac Owners Fanatic
    Automobile(s): 2010 ESV Platinum WDT
    Jan 2013
    South Elgin, IL
    44
    189
    Re: Removing drop kit
    I got mine lower than most on my kelderman/accuair setup. On the 22's it's perfect at 32" front 32.5" rear at fenders. On my 24's I feel a bit more had to bump to 33.75" front and 34.25" rear at fenders to net same ride feel. Enough that I never swapped back to the 24's after winter. Couple shots of her on the 2's.
    Dec 2011
    30
    671
    That's sick! That's why I don't want to put my stock suspension back because it looks so dam good. Is there anything I should worry about? Like control arms or ball joints? I have drop spindles with springs in the back. My friend told me that the eibach sway bars are giving me the stiffer ride.
    soulsea's Avatar
    soulsea is offline Cadillac Owners Enthusiast
    Automobile(s): 2016 Range Rover V8 SC ... 2015 Corvette Z06/Z07
    Nov 2012
    Mt Pleasant SC
    49
    923
    I would take off the sway bars and put the stock ones back and see if the ride improves before taking off the drop. It seems logical that a part meant to reduce roll would stiffen the ride by consequence, although I'm not knowledgable enough to say for sure.
    I actually had a 2/3 drop on 24s on my old Tahoe and she rode like a pig so took it off. There is something called the 'free travel mod' which involves cutting off the bump stop brackets with a sawzall that is supposed to restore the ride quality after the drop, but I'm not sure this applies to autoride trucks like ours. Maybe someone else knows for sure.
    MrHolland's Avatar
    MrHolland is offline Super Moderator
    Automobile(s): 2010 Platinum Escalade, 1996 Fleetwood Brougham
    Jul 2010
    Midwest
    5,683
    Sway bars will make the ride more harsh. That's where I'd begin.
    emay's Avatar
    Jan 2013
    South Elgin, IL
    44
    189
    In order to sit where mine is I first trimmed the bump stops, air out it still sat on the nubs. So I cut out the entire bracket (free travel mod Soulsea mentioned). That freed up plenty of room to get full suspension travel.
    I'm also running a set of hotchkis sways, I got them from Soulsea. I feel no adverse affects in ride stiffness with them on. Body roll is far less in cornering with the combination of the bars and lower center of gravity than when it's aired up that I can attest to.
    Dec 2011
    30
    671
    I think that it's my wheels to tell you the truth.
    soulsea's Avatar
    Nov 2012
    Mt Pleasant SC
    49
    923
    I dunno B ... when I removed my 2/3 drop kit from my Tahoe and went back to stock height the ride quality reverted 95% back to stock through that action alone, taking the 24s off and replacing them with 22s restored the last 5% of the ride. I'd be willing to wager that going down 2" on wheel size alone will not measurably improve your ride quality. It's easy to test out tho if you have a friend close by with a stock Esky willing to swap wheels with you for a few hours.
    Otherwise, revert back to the stock sways, and if you're still not happy with the ride you can decide if you want to cut out you bump stop brackets or remove the drop altogether. But I feel ya, like I said just like you I loved the way she looked but I hated the ride quality:
    Dec 2011
    30
    671
    Quote Originally Posted by soulsea
    Thanks for you help buddy, I might think its my wheels. I have the 24 oem style wheels, I think they are made poorly because the last few months I have noticed that the inside of the wheels are pitting and pealing badly. I think they are way to heavy for the car also.
    My biggest concern of all is the safety of the truck and the drop kit. I get nervous on the high way because it drives really bad. It vibrates a lot and it kind of has a hard time excellerating like the wheels is weighing the car down you know. I had the 24s before the drop and it drove fine.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    The wheels aren't too heavy for the truck, and aren't keeping it from accelerating, or causing vibration. Lowering springs=harsher ride quality and in some cases, accelerated wear on suspension and steering components.
  16. #14
    Dec 2011
    30
    671
    They are not springs tho, they are spindles. The reason why I went with the spindles because it doesn't wear on all the components etc. plus GM gave McGaughys a award for best aftermarket suspension or something like that. But I'm going to start by taking out the sway bars first and see what happens.
  17. #15
    soulsea's Avatar
    Nov 2012
    Mt Pleasant SC
    49
    923
    A drop shouldn't make the truck vibrate if installed properly, and if you got an alignment after it was installed and are using the same wheels as before that didn't vibrate, then it's likely that the installation wasn't done properly. Have the shop double check it when they are swapping sway bars.
  18. Remove Advertisements
