Removing drop kit - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 27 of 27
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, Removing drop kit in Cadillac Escalade Forums; A vibration at speed is an out of balance rotating part. ---------- Originally Posted by BEarle They are not springs ...
  1. #16
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Quote Originally Posted by BEarle
    They are not springs tho, they are spindles. The reason why I went with the spindles because it doesn't wear on all the components etc. plus GM gave McGaughys a award for best aftermarket suspension or something like that. But I'm going to start by taking out the sway bars first and see what happens.
    I thought I saw springs mentioned earlier in the thread.
  2. #17
    36dbldz's Avatar
    36dbldz is offline Cadillac Owners Fanatic
    Automobile(s): 2010 Escalade
    Sep 2012
    The Sunshine State
    308
    Isn't it spindles in front and springs in the rear? It seems most people are not feeling the ride with the drop
  3. #18
    BEarle is offline Cadillac Owners Enthusiast
    Automobile(s): 2010 Cadillac Escalade
    Dec 2011
    30
    671
    I had it aligned twice since the drop. Yeah a lot of people are not liking the ride with the drop. I swore before that I wouldn't screw with the suspension but I had a friend that installed it on his escalade and swore by it so I tried it. The weird thing is, that it drove better with the 26s than the 24s which is odd.
  5. #19
    silkjones is offline Cadillac Owners Member
    May 2013
    15
    Re: Removing drop kit
    I purchased my truck with a drop and let me tell you my 95 mitsubishi has a better ride quality than my cadillac. I need to return it to stock. I'd rather ride high than to hit a bump and feel like my car is about to fall apart. What would I have to purchase to return it back to stock? I need to get that done this week.
  6. #20
    soulsea's Avatar
    soulsea is offline Cadillac Owners Enthusiast
    Automobile(s): 2016 Range Rover V8 SC ... 2015 Corvette Z06/Z07
    Nov 2012
    Mt Pleasant SC
    49
    923
    Quote Originally Posted by silkjones View Post
    It depends what type of drop it is. If it's spindles up front and springs in the rear then you need the OEM front spindles, the OEM rear springs, bumpstops, and autoride links. If the front is dropped with springs then you need the OEM front springs instead of spindles.
    This is just me guessing on the basis of the standard moderate drop kits by Belltech or Mcgaughys. More significant drops may have additional parts or the previous owner might have modified additional suspension components for this specific drop. Best way forward it to take it to a suspension shop or a shop that does these types of mods, have them look at it, and see what parts have actually been modified so you know what OEM parts you need.
  7. #21
    May 2013
    15
    Quote Originally Posted by soulsea View Post
    Thanks a lot! Will go that route this week.
  8. #22
    soulsea's Avatar
    Nov 2012
    Mt Pleasant SC
    49
    923
    You're very welcome ... hopefully the previous owner used a standard kit rather than a a bunch of mismatched ebay parts, it'll make it a lot easier to spot what needs to be put back to stock. If it's only springs, bumpstops, and autoride links it shouldn't be too expensive to get the OE parts, spindles are a little more expensive, both to buy and in terms of labor for a shop to swap them out.
  9. #23
    rgb129 is offline Cadillac Owners Member
    Automobile(s): 2009 Escalade
    Jun 2013
    50
    Are these problems on the 3/5 drop or the 2/3 or both? I really wanted to do the 2/3 drop on mine, but reading this thread makes me leary.
  10. #24
    Dec 2011
    30
    671
    I have a 2/3 drop. I'm going to start by putting the stock sway bars back in and see how it is after.
    Does anyone run billstein shocks? Will I get a better ride if I install those.
  11. #25
    soulsea's Avatar
    Nov 2012
    Mt Pleasant SC
    49
    923
    Don't you have magnetic ride?
    I don't think you can just throw any shock under there.
  12. #26
    Dec 2011
    30
    671
    I'm not sure it's a 2010 premium
  13. #27
    May 2013
    15
    I'm just getting a chance to take the car in...i'm actually taking it to the dealer because struts are covered by my aftermarket warranty. I'm so glad that I got the platinum warranty that covered all of those parts. I'll just pay my $250 ded and let them fix everything. My stabilitrak light came on, i need my suspension checked, i have a leaky sunroof, my windshield wipers sometime stop for some unknown reason, and my transmission is taking a while to catch when I put it in reverse. I will definitely report back on the ride quality once this drop is removed.
  14. Remove Advertisements
