Push Button Start system installed - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 38 of 38
Like Tree7Likes
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, Push Button Start system installed in Cadillac Escalade Forums; Remote Start still keeps me smiling...
  1. #31
    Escapade is offline Cadillac Owners Fanatic
    Automobile(s): '07 QuickSilverLade
    Feb 2009
    Toronto
    287
    Re: Push Button Start system installed
    hannity likes this.
  2. #32
    lilpenny1 is offline Cadillac Owners Member
    Automobile(s): 2008 escalade
    Nov 2009
    47
    41
    @babylade, nope so far no problems. What's the name of the system you are looking at? This one is made for GM Vehicles.
  3. #33
    babylade is offline Cadillac Owners Member
    Automobile(s): 2007 Escalade 2WD
    Jan 2011
    Jacksonville, FL
    36
    Just had this iKEY RS from Digital Guard Dawg installed today and it’s 95% perfect. My installer had the ‘lade for 6 hours to remove an alarm system (to fix the sh!**y Viper install) and install it right.
    BAD: Still have to use a key in the ignition to put it in gear. We are working on solving that, so it’s truly “keyless”.
    Round antennas are visible through the glass (front & back)
    GOOD: RFID lock and unlock works perfect.
    Push start is cool and has 3 modes (Start, ACC for radio only, and ACC plus fans and stuff)
    Has an alarm system.
    Remote start works like before.
  5. #34
    Nice Ride is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 ESV Platinum / 2013 SRX Premium
    Jan 2012
    1,290
    Keep us posted...
  6. #35
    Nov 2009
    47
    41
    You should of used the system I have, much better. No problems so far.
  7. #36
    Jan 2011
    Jacksonville, FL
    36
    @lilpenny1, I considered it but also wanted the RFID keyless entry. This was the only system that would do it all without having two seperate systems to install. Is your shifter always unlocked, or does it unlock when you start it?
  8. #37
    Nov 2009
    47
    41
    I have keyless entry also. I walk up to the door and I can unlock or lock the door w/o pressing the key fob. Are you referring to that or something different? I believe the shifter is unlocked on start.
  9. #38
    Jan 2011
    Jacksonville, FL
    36
    The lock/ unlock function I was after is the same as Corvettes and others, where it senses the FOB within a few feet then locks/ unlocks. What I've found out is that GM's security will only unlock the shifter with a key, so it has to be disabled or have a modded key inserted and turned to ACC (covered or uncovered). In either one of those, the truck can be put into gear when it's not running and I'm not comfortable knowing that could happen.
  10. Remove Advertisements
