08 squeaking noise
Results 1 to 8 of 8
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, 08 squeaking noise in Cadillac Escalade Forums; My 08 6.2 awd has a squeaking noise coming from the rear pass wheel, the faster I go the faster ...
    02caddilade is offline Cadillac Owners Member
    Automobile(s): 2002 escalade awd 6.0
    Aug 2010
    37
    48
    08 squeaking noise
    My 08 6.2 awd has a squeaking noise coming from the rear pass wheel, the faster I go the faster the squeak the slower I go thevskowervthe squeak . If I hit my brakes it makes no difference, any ideas?
    bruin300 is offline Cadillac Owners Member
    Dec 2011
    42
    Any answers to this comment? I have the same issue on a 08' AWD. Except that If I step on the brake lightly, while the brake pedal is down the noise goes away. When I let go of the brake pedal the noise comes back.
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,674
    Re: 08 squeaking noise
    Hello 02caddilade and bruin300,
    I am unable to offer advice as to what this issue could be due to not being a certified technician. If you private message me with your VIN, I am more than happy to research this issue for you to see what I can find. If either of you are willing to work with a dealership on this concern, please also let me know via private message if you choose to continue to interact with me.
    Sincerely,
    Laura M.
    blackex is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Cadillac Escalade Base
    Aug 2010
    Troy, Michigan
    31
    380
    I would check the wheel bearings for the noise first. They are commonly replaced around 100,000k miles. How many miles do you have?
    MrHolland's Avatar
    MrHolland is offline Super Moderator
    Automobile(s): 2010 Platinum Escalade, 1996 Fleetwood Brougham
    Jul 2010
    Midwest
    5,639
    Quote Originally Posted by bruin300 View Post
    Your issue sounds like brakes. I'd begin with checking them. Replacing them may be in order.
    Aug 2010
    37
    48
    Mine has 75k, it's the rear passenger tire on mine, i was told maybe a u-joint?
    Dec 2011
    42
    68,000 on mine. The dealer replaced the cap on the rim. That didn't do it. I replaced the rear brakes and that didn't do it. My noise also comes from the rear passenger area.
    Aug 2010
    37
    48
    Took it to my mechanic today , he pulled off the tire, rotor and caliper, cleaned everything and now the noise is gone
  11. Remove Advertisements
