Check charging system on DIC
Results 1 to 3 of 3
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, Check charging system on DIC in Cadillac Escalade Forums; My battery light indicator light is on and on my DIC panel shows check charging system. Does this mean my ...
    ESCALADE132's Avatar
    ESCALADE132 is online now Cadillac Owners Fanatic
    Automobile(s): 2009 Escalade
    Mar 2010
    SC
    47
    379
    My battery light indicator light is on and on my DIC panel shows check charging system. Does this mean my battery is going bad?
    Thanks
    K9Caddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 AWD Escalade Ultra Luxury Raven Black
    Oct 2009
    Illinois
    38
    1,492
    Re: Check charging system on DIC
    Could either be a bad battery or your alternator is going bad, or both. I wouldn't prolong getting it fixed, because if the battery is bad, you are straining the alternator to keep up.
    Or, could possibly be something as a loose ground, just get it checked. A simple load tester and a voltage meter can detect either problem.
    Alegre323 is offline Cadillac Owners Member
    Automobile(s): 2007 Escalade
    Mar 2013
    30
    Loose ground wire on the battery. Remove the negative side and re attach it. Happened to me 3 weeks ago. Problem solved
