Power Seat Doesn't Work
Results 1 to 2 of 2
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, Power Seat Doesn't Work in Cadillac Escalade Forums; Hey all, I've got a persistent issue with my driver's side power seat. It doesn't always work. It's all or ...
    Banshee8732 is offline Cadillac Owners Fanatic
    Automobile(s): 2012 Escalade Premium
    Mar 2013
    WI
    28
    172
    Hey all, I've got a persistent issue with my driver's side power seat. It doesn't always work. It's all or nothing. When it works, all 3 buttons work. When it doesn't, none of them do. My dealer replaced the switch for the seat last week. I thought that fixed it since it was working fine until today. Now it's not working all the time again. It seems to take less time than before the switch was replaced to work again but something is still disjointed somewhere.
    The easy exit seat works even less often. If the rest of the seat is fine, I can hit the easy exit button on the door and it's good to go. Taking the key out of the ignition almost never activates the easy exit feature. It's only worked twice since last Thursday. The option is turned on in the DIC. When it has worked by taking out the key, it doesn't return automatically. I have to hit the recall button on the door.
    Anybody have any ideas?
    anhandrew is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Escalade ESV modded out, 2013 ATS LUX 2.5L
    Jul 2009
    Moore, OK
    144
    Re: Power Seat Doesn't Work
    I have this issue too. However try lifting your butt from the bottom cushion and see if it helps power the seats again. After much trial and error i found the following.
    If i lift the bottom of the leg(bottom of the knee) up i get power again. I seems like there is a short in the wiring of shorts. I have ordered a new wire set but have yet to have time to put it in. Probaby do that this weekend.
    Thanks,
    Andrew
