Need help replace HID headlights.
Results 1 to 9 of 9
Like Tree1Likes
  • 2 Post By soulsea
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, Need help replace HID headlights. in Cadillac Escalade Forums; I replace my hid light with the same osram D1S ,but is not the same as my other one this ...
    MrCraneOp is offline Cadillac Owners Member
    Automobile(s): 2007 Cadillac Escalade Ext
    May 2013
    38
    5
    I replace my hid light with the same osram D1S ,but is not the same as my other one this new one from O'rellys is more of a warm light my other one has a brighter
    White and hint of blue.I bought this 2007 cadillac escalade ext truck back on 2008
    i was not the first owner .Don't know what kind of hId are they like 5000k or 6000k but I'm sure they are not 4300k so need help how can I found out which is the one I had still have the right side n can tell the
    Different light !
    shore is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 Escalade
    Nov 2008
    Port Orange, Florida
    44
    637
    Re: Need help replace HID headlights.
    4300 is semi yellowish
    5k will be whiter
    6k will be bluer.
    May 2013
    38
    5
    @Shore thanks
    Question is there any possible to know what kind I have now by looking at the bulb!
    I got the Osram 66141 and I bought one similar but don't match with the left light !
    Do they change color after hours of working ?
    Nov 2008
    44
    637
    not that I know of and these bulbs are pita to change.
    BlownEscalade is offline Cadillac Owners Fanatic
    Automobile(s): '11 Escalade, '06 Escalade
    Jun 2006
    Edmonton, Alberta, Canada
    221
    When you replace hid lights, you replace both. As the color will change after a while.
    soulsea's Avatar
    soulsea is offline Cadillac Owners Enthusiast
    Automobile(s): 2016 Range Rover V8 SC ... 2015 Corvette Z06/Z07
    Nov 2012
    Mt Pleasant SC
    49
    923
    Quote Originally Posted by MrCraneOp View Post
    @Shore thanks
    Yes hid bulbs colorshift during their lifespan, they turn bluer, purple, and eventually lose all their output. This is most likely the case with the bulb you haven't changed, and it is the same but fading 4300K bulb you have now that needs to be changed. Like BE said, it is always recommended to change both bulbs when one goes out to keep a consistent color temp.
    It's too bad you didn't look at the for sale section stickied at the top cause I have an almost brand new pair of matching bulbs for $50 shipped.
    Banshee8732 and Banshee8732 like this.
    May 2013
    38
    5
    Ok thanks got the info I was looking for !
    Also I was thinking about upgrading to 5000k
    I don't like that yellowish color so I hear 5000k are more of a white/brighter color ! Any body out there know where can buy them ? Thanks!
    Also should I go with 5000k or just keep stock 4300k ?
    soulsea's Avatar
    Nov 2012
    Mt Pleasant SC
    49
    923
    These are the only OEM 5000K D1S bulbs in existence: http://www.theretrofitsource.com/pro...ducts_id=17166
    They are what I've used on my older and newer escalades:
    May 2013
    38
    5
    Ok thanks!
  12. Remove Advertisements
