guys need help with the wifes truck
Results 1 to 10 of 10
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, guys need help with the wifes truck in Cadillac Escalade Forums; Truck is out of warranty,has 76,000 miles on it,and is making a noise from the drivers side front end,when your ...
    gp1200r2000 is offline Cadillac Owners Member
    Oct 2010
    44
    15
    Truck is out of warranty,has 76,000 miles on it,and is making a noise from the drivers side front end,when your drive and are going around a turn around maybe 20-40 mph and not a sharp turn its making a grinding sound and when your going straight it sounds like metal rubbing together but not loud at all,and once in a blue moon she said it sounds like on a turn that something is clicking a little bit,any help would be greatful
    Thanks
    Ran-Dom32 is offline Cadillac Owners Member
    Automobile(s): 2007 Escalade '08 CTS '06 H2
    Apr 2013
    41
    95
    Re: guys need help with the wifes truck
    sounds like a bad wheel bearing
    Oct 2010
    44
    15
    What would make the sound like it slapping around a little bit?? is there another way of telling if its that,also you dont think its a axle or rack
    brooklynallstar is offline Cadillac Owners Member
    Aug 2010
    VA Beach
    33
    I had the same problem. It would happen sometimes when I was turning a corner. My wife thought it was because of cold weather. I forgot what the dealer said it was but it was $90 to fix on top of the standard oil change. If you describe it to them they should know what it is. It's a known problem from my understanding.
    SouthernCaddy's Avatar
    SouthernCaddy is offline Cadillac Owners Fanatic
    Automobile(s): Escalade ESV
    Jan 2010
    Ellerslie, Georgia, United Sta
    52
    275
    Front hub bearing. Better check it now, it will leave her stranded if you dont make sure.
    Cadsrfun is offline Cadillac Owners Member
    Automobile(s): 2010 Silver Escalade ESV Platinum
    Jan 2012
    Templeton CA
    61
    Squat down in front of the wheel and grab the top of the tire with both hands and pull toward you in a rocking motion. It should make a clicking noise for a bad bearing or hub. Then go to the other side and there should be no noise or relative motion. Give it a try.
    rbh23456 is offline Cadillac Owners Member
    Automobile(s): 2008 Escalade ESV
    May 2013
    42
    16
    Definitely sounds like the wheel hub assembly. I just replaced both front assemblies on my 2007 with 70k. First time I had ever done it, but it wasn't too bad. Once I heard that noise, mine failed rather quickly. And I thought mine was the drivers side, but it turns out the passenger side was where all the noise was coming from.
    Eric Hagan's Avatar
    Eric Hagan is offline Cadillac Owners Fanatic
    Automobile(s): 07 Escalade
    Apr 2011
    35
    158
    How much did it run for two bearing assemblies?
    sj1400 is offline Cadillac Owners Fanatic
    Automobile(s): 07 ESV
    Sep 2006
    140
    The wheel hub on the drivers side front went first. Failed 30 miles from home on a 2k mile road trip. Had to get a flatbed to tow it. A few months later the passenger side failed. I recognized the noise and went straight to the dealer.
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,674
    Quote Originally Posted by sj1400 View Post
    Hello sj1400,
    I am sorry for the wheel hub issue your vehicle experienced. I am glad you were able to recognize the noise a few months later when your vehicle experienced the same issue on your passenger side. I hope everything is working well now with your vehicle and you are enjoying your Escalade. If there are questions that you have, or any concerns you would like to discuss, don't hesitate to reach out to us.
    Sincerely,
    Laura M.
  13. Remove Advertisements
