Results 1 to 5 of 5
Thread: 6.2 Escalade Oxygen Sensor help
    TabletDash's Avatar
    TabletDash is offline Cadillac Owners Member
    Automobile(s): 2007 Escalade
    May 2013
    Fort Lauderdale, FL
    34
    10
    I'm replacing my 02 sensors and I'm wondering what part numbers, how many and where can I get them? Thanks
    I've been told there are two then someone else said 4..... I've heard upstream and downstream
    UPSTREAM
    DOWNSTREAM
    Also what make should I be looking for? Thanks
    Brand not "make"
    wesyder's Avatar
    wesyder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
    Mar 2009
    Eastvale Calif
    1,812
    Quote Originally Posted by TabletDash
    UPSTREAM
    DOWNSTREAM
    Brand not "make"
    There are 2 before the catalytic's and 2 after, so 4 total
    TabletDash's Avatar
    May 2013
    Fort Lauderdale, FL
    34
    10
    Re: 6.2 Escalade Oxygen Sensor help
    Ok and I'm guessing the two before are called upstream
  5. #4
    wesyder's Avatar
    Mar 2009
    Eastvale Calif
    1,812
    Roger that
  6. #5
    Tec80 is offline Cadillac Owners Fanatic
    Automobile(s): DHS, 2007 ESV
    Mar 2010
    241
    Watch out for the brand of replacement sensor, some aftermarket sensors have a slightly different calibration and will make the engine run slightly richer or leaner, depending on which way they are off. Ran into this with a replacement Bosch Oxygen sensor vs. OEM AC on my GN about 20 years ago. The Bosch ran too lean and caused driveability issues.
  • You may not post replies
