2007 Fast Blink
Results 1 to 5 of 5
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, 2007 Fast Blink in Cadillac Escalade Forums; Hello to everyone.. I have searched the forum and found similar issues but no resolution to the issue. I have ...
    BigPerty2007 is offline Cadillac Owners Member
    Automobile(s): 2007 Escalade ESV
    May 2013
    48
    9
    2007 Fast Blink
    Hello to everyone.. I have searched the forum and found similar issues but no resolution to the issue. I have a 07 esv and Im getting a fast blink on drivers side turn signal. I have no break light on drivers rear but do have the parking light.
    I have cleaned the connector under the body and Im trully hoping the LED tail light hasnt run its course.. Any help is greatly appreciated!
    Thank you!
    Tec80 is offline Cadillac Owners Fanatic
    Automobile(s): DHS, 2007 ESV
    Mar 2010
    241
    Re: 2007 Fast Blink
    Check the wires going from the taillight into the connector. The salt sprays up off the rear tires and can corrode the wires where they go into the terminals. If they look all green and corroded, that's the likely cause.
    May 2013
    48
    9
    Re: 2007 Fast Blink
    I cleaned the wire harness and nothing. I was gonna swap the tail lights to try and determine if it was actually the tail light. All of a sudden. . Its now working!
    May 2013
    48
    9
    Re: 2007 Fast Blink
    Well its intermittent. . It stopped working and then started again. Any recommendations on what I could better clean the connectors with?
    blackex is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Cadillac Escalade Base
    Aug 2010
    Troy, Michigan
    32
    380
    Re: 2007 Fast Blink
    electrical cleaner spray you can pickup at any auto store. Also inspect the connectors for breakage. They may be becoming disconnected while driving or there is a loose wire.
  8. Remove Advertisements
