broken manifold bolts = $1400??
Results 1 to 2 of 2
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, broken manifold bolts = $1400?? in Cadillac Escalade Forums; to pass inspection they want to replace a broken exhaust manifold bolt at the rear of both sides of the ...
    psuscott0483 is offline Cadillac Owners Member
    Automobile(s): 07 EXT
    May 2012
    Kutztown, PA
    33
    39
    to pass inspection they want to replace a broken exhaust manifold bolt at the rear of both sides of the engine. if the bolts come out it could be about 800$ but if the bolts do not come out easy and must be drilled they want $1400 to remove the top of the motor to get at the bolts. anyone had this happen to them?
    blackex is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Cadillac Escalade Base
    Aug 2010
    Troy, Michigan
    32
    380
    Re: broken manifold bolts = $1400??
    I had a bolt break off on the drivers side rear like you mentioned. The shop wanted $275 to tap and replace the bolt and gasket for one side. Not sure why they are charging so much. Get another quote elsewhere to compare?
