Annoying slow leak
Results 1 to 8 of 8
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, Annoying slow leak in Cadillac Escalade Forums; My left front tire is losing 1-2 psi per day. Seems to loose faster when I am driving. Have pulled ...
    cutterman is offline Cadillac Owners Fanatic
    Automobile(s): 2011 Escalade Premium Edition
    Jun 2009
    185
    Annoying slow leak
    My left front tire is losing 1-2 psi per day. Seems to loose faster when I am driving. Have pulled the tire off 3 times and inspected visually and with soapy water and can't find it. Checked along bead, stem etc.
    Before I bring the tire in to be removed and remounted was wondering if anyone had a similar experience.
    Thanks
    MrHolland's Avatar
    MrHolland is online now Super Moderator
    Automobile(s): 2010 Platinum Escalade, 1996 Fleetwood Brougham
    Jul 2010
    Midwest
    5,659
    Re: Annoying slow leak
    People have reported the same with rusted/corroded rims.
    Naf's Avatar
    Naf
    Naf is offline Cadillac Owners Connoisseur
    Apr 2007
    2,090
    It could be a tiny nail in your tire, inflate to 45psi and get soapy water in a spray bottle, spray the thread and rim area to find your leak and plug the thread area only, if leaking from the side wall change immediately...
    On my old cars the TPMS stem use to leak all the time
    Jun 2009
    185
    Thanks for the tip. Will give it a try.
    the blur's Avatar
    the blur is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac
    Oct 2008
    NY
    1,016
    Water bath will find it every time.
    flasrx is offline Cadillac Owners Member
    Nov 2003
    32
    As posted above, there is a very good chance it is the corrosion inside the rims. I had the same problem and went to my local Discount Tire store several times due to a slow leak. They could never find anything wrong with the tire. But after about the third visit the guy showed me the rim corrosion. I live in Florida, so I know it wasn't road salt that caused it. Because the chrome was peeling on that one rim and I told my Caddy dealer about the inside corrosion, they agreed to replace all four rims for free. It is a know issue. BTW, mine is an 08.
    Jun 2009
    185
    Yep- that was it.
    The leak worsened and I found it on the inside rim. Broke the bead there and the plating had pealed and there was a lip of corrosion. I sanded it down and applied rubber cement and it seems to be sealed. I was surprised since the car is an '11 and the rims were not used in the winter.
    If it happens again I am bringing it to the dealer to have the rims replaced.
    the blur's Avatar
    Oct 2008
    NY
    1,016
    Most of the GM wheels are made in Japan, or some other foreign country.
  11. Remove Advertisements
