Aftermarket Headunit vs. original
Results 1 to 5 of 5
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, Aftermarket Headunit vs. original in Cadillac Escalade Forums; Hi I was wondering if anyone could tell me what solution might be the best: A) replacing my Radioheadunit with ...
    Alpha.Romeo is offline Cadillac Owners Member
    Mar 2013
    35
    Hi
    A) replacing my Radioheadunit with a Navi Headunit and putting in some extras (rear cam, lockpicks) as seen on OEMAUTOPARTS
    B) replacing my Radioheadunit with a aftermarket system (Alpine/Pioneer)
    My problem is that I need a European system because I live in Munich. The other thing is that I have Sport Luxury model and would like to remain my rear seat entertainment system installed an would like to use it for example with an alpine system
    zach2011's Avatar
    zach2011 is offline Cadillac Owners Fanatic
    Automobile(s): 2010 Escalade Luxury w/Full Platinum Exterior
    Apr 2010
    23
    264
    Re: Aftermarket Headunit vs. original
    I don't know about tying a factory DVD system in with an aftermarket head unit but I'm sure it's possible. If it were me, however, I would just go with a factory system because I like the clean factory style look. Especially on a $70k-$80k vehicle. Plus, the lockpicks are pretty sweet for overriding limitations and adding multiple cameras.
    I'm just not an aftermarket person so personally I recommend the 2012+ Nav system with the CF card reader and USB support (although any nav 2010+ will have USB). Then you just obtain the European version CF card for your map data. You'd have the lock pick and rear camera for some cool new features, full factory USB/iPod integration, reverse camera with color guidelines, and more. And it is guaranteed to work with your factory rear seat entertainment with no advanced wiring needed.
    And if you desire aftermarket sound, then just change out your speakers, although the Bose system is pretty powerful and it is hard to find aftermarket speakers that beat it without spending a ton.
    franknitty69's Avatar
    franknitty69 is offline Cadillac Owners Member
    Automobile(s): 2008 Cadillac Escalade
    Mar 2011
    Washington, DC
    51
    i would go aftermarket. more features and better navigation. if you use a metra or pac interface you will be able to retain your rear seat entertainment. the only caveat is that you won't be able to control RSE from the back, only from the front.
    for instance, from the rear, you will no longer be able to switch between fm, xm, etc. you have to set the rear source from the new head unit.
    eljefe7070's Avatar
    eljefe7070 is offline Cadillac Owners Member
    Automobile(s): 2008 Escalade
    Apr 2013
    Virginia Beach, VA
    36
    3
    Crutchfield does offer a PAC interface to help with maintaining the stock SUB, AMP, Steering wheel controls, back up camera, and onstar features. IMHO i prefer it that the folks in the back were not able to change inputs. I'm searching for a screen that I can install above the new headunit. So I can roll with two screens in the dash, 1 over head and two headrest monitors.
    Did a search and the only working setup I have seen was in Japan. Anyone else seen this type of setup done before?
    wesyder's Avatar
    wesyder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
    Mar 2009
    Eastvale Calif
    1,797
    Quote Originally Posted by eljefe7070
    Ive installed that interface in a buddy's 2012 yukon xl, it made the install sweet
  8. Remove Advertisements
