2007 Escalade ESV Bluetooth Help
Results 1 to 12 of 12
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, 2007 Escalade ESV Bluetooth Help in Cadillac Escalade Forums; Hi everyone, Just got my 2007 ESV and loving it and the contribution to my local gas station I realized ...
    bellevue is offline Cadillac Owners Member
    Automobile(s): 2007 escalade esv
    May 2013
    3
    Hi everyone,
    I realized that the car does not have Bluetooth? I guess that started with later models..
    Anyways, I see some threads about replacing a VCIM??
    Does anyone have any links to where I can get one and also a step by step on how to install?
    After the install will I be able to connect my phone and play iTunes via Bluetooth or will this be only for phone?
    Thanks so much for the help!
    zach2011's Avatar
    zach2011 is offline Cadillac Owners Fanatic
    Automobile(s): 2010 Escalade Luxury w/Full Platinum Exterior
    Apr 2010
    24
    264
    Re: 2007 Escalade ESV Bluetooth Help
    If you install a new VCIM you will gain Bluetooth functionality, and if you purchase a VCIM with version 9.3 software, then you also get OnStar RemoteLink (if you subscribe) where you can start the car from anywhere with your phone as well as other things. Installing the new VCIM is pretty easy, you just remove the wood trim near the radio (cupholder area, radio surround, and long passenger side AC vent) and they just pop out, held in by clips. Then you unbolt the radio, remove it, and the VCIM is under where the radio sits.
    You will not, however, be able to stream audio via Bluetooth to your car's radio. For that you would need an aftermarket Bluetooth unit. If you want to play your phone's music through the car's stereo, I suggest an iSimple module which adds factory-like iPhone connection to the radio for audio playback as well as charging. You can even operate it through the steering wheel controls. For a factory setup of this, you could upgrade the radio in your truck to a 2010+ unit with the USB integration.
    blfromni is offline Cadillac Owners Member
    Automobile(s): none
    Apr 2012
    40
    1
    anyone know the cost of a 2010 factory setup?
    shore is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 Escalade
    Nov 2008
    Port Orange, Florida
    44
    637
    are you sitting down?
    I'd love to use my touch through the factory NAV but there are almost always an issue with those adapters...either they are very expensive or they are quirky and don't work right. I had one in my 05 and it was more trouble than good.
    Things might have changed by now but i bet you have to jump through hoops and pay out your arse to get a good adapter to play itunes/MP3 through the factory NAV.
    psuscott0483 is offline Cadillac Owners Member
    Automobile(s): 07 EXT
    May 2012
    Kutztown, PA
    33
    39
    just installed a vcim i found on eBay for $300 easy swap easy sync works perfectly for calls. audio i pit in a lockpick and can control the ipod via touch screen imo easy as btooth & charges while playing. never really understood why youd need/want to start your car with the app when youd be out of sight of the car (assuming your keys remote start is out if range)
    Nov 2008
    44
    637
    what lockpik and how was the install?
    May 2013
    3
    Zach,
    Thanks for the info.
    I think your advise is accurate re: VCIM and I looked into isimple or USA spec for the music part.
    The VCIM unit is behind the radio but if was to only install the isimple or USA spec, where would it go and where would the connector line come out off? Center Console?
    Factory setup upgrade way too much $$.
    Thanks!
    Nov 2008
    44
    637
    I have XM, is this located through the glove box in my 07? isimple or usa spec better?
    does this mean I lose my XM?
    May 2012
    Kutztown, PA
    33
    39
    gmx550 install was easy - I placed it below the cup holder. it would not seem to fit anywhere else behind the radio/climate controls. so I ran the wire harness down behind all the metal brackets to make more room, and I taped up the holes in my cup holder so that if I were to spill a drink it would not go down onto the lockpick. drilled a hole in the center console and fished the ipod cable up through, so it is all hidden and I can easily get to my ipod if I want to disconnect for sync
    statonville is offline Cadillac Owners Member
    Automobile(s): 2007 Cadillac Escalade ESV
    Aug 2016
    1
    I have a 2007 ESV. I bought the VCIM with the antenna, installed it and when I push the steering wheel button for talk, it just makes the stereo quiet. I can touch my mirror for Onstar and it connects, but not the steering wheel and there is no place for bluetooth... it doesn't work. Can someone please give me some advice?
    BCassie is offline Cadillac Owners Member
    Automobile(s): 2007 Escalade Platnum
    Aug 2016
    50
    You say " If you want to play your phone's music through the car's stereo, I suggest an iSimple module which adds factory-like iPhone connection to the radio for audio playback as well as charging. You can even operate it through the steering wheel controls. For a factory setup of this, you could upgrade the radio in your truck to a 2010+ unit with the USB integration"
    Where do you get this module ?
    CoupeDTS is offline Cadillac Owners Enthusiast
    Automobile(s): 66 DeVille Vert / 07 Escalade ESV / 96 Fleetwood / 83 Coupe Deville / 70 Calais Sedan
    Nov 2010
    Lincoln, Nebraska
    35
    568
    isimple are on amazon or ebay.
  15. Remove Advertisements
