2007 Escalade - running board lights, heated seats problems
Results 1 to 12 of 12
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, 2007 Escalade - running board lights, heated seats problems in Cadillac Escalade Forums; 2007 escalde running boards not working and front heated seats not working . What do i need to replace? Can ...
    slickCadillac's Avatar
    slickCadillac is offline Cadillac Owners Member
    Apr 2013
    7
    2007 escalde running boards not working and front heated seats not working . What do i need to replace? Can anyone help?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,148
    Re: help please !!!!!
    You will be far, far better off with this up in Escalade. "Help please !!!!" doesn't define your problem - I'll change the thread title to be more descriptive.
    Moved to Escalade forums.
    blackex is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Cadillac Escalade Base
    Aug 2010
    Troy, Michigan
    32
    380
    Re: 2007 Escalade - running board lights, heated seats problems
    You have automatic running boards? I've heard nothing but problems with those and i'm glad my 2007 has the fixed running boards. I would check the electrical connections for the running boards including fuses. Same with the heated seats, I would check the fuses. If all else fails I would go to a dealership and have them diagnose the problem. If you don't like their diagnosis and believe it's overpriced then I would take their findings and go to a reputable auto repair facility and take their findings to them to see what they have to say as well as their price.
    emay's Avatar
    emay is offline Cadillac Owners Fanatic
    Automobile(s): 2010 ESV Platinum WDT
    Jan 2013
    South Elgin, IL
    44
    189
    I'd start with a good thumb through some of the threads on this forum regarding heated seats, there's been several home wrenchers resolve those issues:
    http://www.cadillacforums.com/forums...archid=1054593
    Have to assume you have the auto runners, this too has had a number of thread discussions. I just had to replace the drivers side motor on my 09 the saturday before easter. Started off as intermittent and evolved to a fully inoperable winker. Got the motor off a totaled 08 at a local pick n pull for 40 bucks. An hour on my back in the garage and she was good as new. Check your fuses, check your plugs. If everything looks good there, check your loads at the motor. I narrowed my issue to the motor by this means.
    zach2011's Avatar
    zach2011 is offline Cadillac Owners Fanatic
    Automobile(s): 2010 Escalade Luxury w/Full Platinum Exterior
    Apr 2010
    24
    264
    Why does the title have "running board lights"? The OP doesn't mention anything about lights and the running boards themselves are not lit...That "more descriptive" moderator edit turned out to still be misleading lol.
    Apr 2013
    7
    I had a electronic problem the harness it was rubbing on the frame and causing my truck to shut down everytime it was moist out. Im thinking there is a module or something that got burned out during the electrical problems. Im guessing what burned out may control the heated front seats and the running boards.
    I checked all the fuses and i have no power coming to the running boards.
    Any help would be great and thank you for all of the responses.
    soulsea's Avatar
    soulsea is offline Cadillac Owners Enthusiast
    Automobile(s): 2016 Range Rover V8 SC ... 2015 Corvette Z06/Z07
    Nov 2012
    Mt Pleasant SC
    49
    923
    There is a module that underneath the power assist step assembly that controls them, and on some trucks also controls the blind zone alert.
    Have a look under there and make sure all the harnesses are plugged all the way in.
    Apr 2013
    7
    You think it may control the heated seats as well? I don't have the blind spot warning its a 07. The back seat heat work just fine its just the front. Any clue where i should start looking for this, driver side or passenger any any info would be truly helpful.
    soulsea's Avatar
    Nov 2012
    Mt Pleasant SC
    49
    923
    I dunno bud, the two issues might or might not be related. I just note where the PAS module is in case you wish to double check it.
    Apr 2013
    7
    And its not the lights on the running boards its the boards themselves not working.
    Thanks I will check that. I really appreciate your input.
    Apr 2013
    7
    Still no go on the boards or seats. It has to be some simple that runs both things. Its driving me nuts.
    edyvill's Avatar
    edyvill is offline Cadillac Owners Member
    Automobile(s): 07 Cadillac Escalade Ext
    Apr 2007
    El Paso
    29
    14
    Hello I am having same problems with my running boards. Went to the dealership and wanting to charge 750.00 for module and installation ?!? Is this correct ?
    Have you found a solution ??
  15. Remove Advertisements
