Transfer Case - BW 4485-NR3 or NVG 246-NP8?
Results 1 to 4 of 4
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, Transfer Case - BW 4485-NR3 or NVG 246-NP8? in Cadillac Escalade Forums; Hi, i am planning to do a transfer case oil change on my 2007 Escalade. According my 2007 Service Manual ...
    Jochen is offline Cadillac Owners Fanatic
    Automobile(s): Escalade
    Jul 2009
    102
    Hi,
    According my 2007 Service Manual there are two different TC possible in that truck. Either a Borg Warner 4485-NR3 or the NVG 246-NP8. I searched the forum for recommended fluid and found many guys telling a DEXRON VI oil should be used.
    My service Manual recommends the following:
    For the BW 4485 - "Manual Transmission Fluid" GM P/N 88861800
    For the NVG 246 - "Auto Trac II Fluid" GM P/N 12378508
    Two Questions:
    - On the RPO Sticker i found Code "NR3". Does that mean i have the BW 4485-NR3 in my Escalade?
    - What fluids would you guys recommend if the OEM Part number fluids are not accessible?
    Any addvice is higly appreciated!
    Best regards,
    Jochen
    Damndirtyape is offline Cadillac Owners Member
    Automobile(s): 07 Escalade EXT
    Jul 2012
    92
    Re: Transfer Case - BW 4485-NR3 or NVG 246-NP8?
    there are typically tags on TCs and differentials that will tell you exactly what it is. It might be covered with crud after 6 years of service but should be there. Some quick googling leads me to believe you'd have the BW unit but it wasn't an exact match. Might want to call a dealer or Caddy cust service and give them your vin to find out which fluid p/n is appropriate.
    Jul 2009
    102
    Thanks! Well, i have to do oil change soon, so i guess i will have a quick look....
    Jul 2009
    102
    I had a look on the Transfercase. It is the Borg Warner. So, my Service Manual says i have to use "Manual Transmission Fluid" GM P/N 88861800. However, i do not get any oil with that classification here in germany. Any idea what i should use? Thanks!
    Jochen
  7. Remove Advertisements
