New 24" Wheels on my ESV - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 51
Like Tree5Likes
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, New 24" Wheels on my ESV in Cadillac Escalade Forums; do the 295/35/24s have the same rubbing issue in liner and PAS? pics anyone...
  1. #16
    36dbldz's Avatar
    36dbldz is offline Cadillac Owners Fanatic
    Automobile(s): 2010 Escalade
    Sep 2012
    The Sunshine State
    308
    Re: New 24" Wheels on my ESV
  2. #17
    ELUSIVE is offline Cadillac Owners Enthusiast
    Automobile(s): Porsche Cayenne Diesel, Porsche 997 Carrera S, VW Passat SE
    Nov 2010
    Colorado, USA
    42
    595
    I just did some research on the differences between stock (285/45/22) and these two 24" options (305/35/24 & 295/35/24). I probably should have done this before.
    You can notice that the 305/35/24 is .8" wider than the stock 285/44/22.
    The 295/35/24 looks to be closer to the same outer size as the stock 285/45/22. Interesting stuff:
    A couple other pics for those that are interested:
  3. #18
    zach2011's Avatar
    zach2011 is offline Cadillac Owners Fanatic
    Automobile(s): 2010 Escalade Luxury w/Full Platinum Exterior
    Apr 2010
    24
    264
    Those look great. I just got the 22's for mine. I wonder what those would look like on a standard wheelbase Escalade.
  5. #19
    Nov 2010
    Colorado, USA
    42
    595
    Quote Originally Posted by zach2011 View Post
    Thanks.
    I did a quick Google search and I found the following:
  6. #20
    zach2011's Avatar
    Apr 2010
    24
    264
    Wow. Still looks just as great. Any difference in ride quality? I would be afraid to turn sharp corners unless the wheel well was modified for more room.
  7. #21
    Nov 2010
    Colorado, USA
    42
    595
    The ride quality isn't all that much different actually. Maybe a tad harsher due tot he lower profile tires.
    The tires are also considerably wider (305's), so there is a more responsive feel and it's more prone to following the road grooves.
    I'm having some issues with rubbing of the wheel well liner and power assisted steps, but only at 80%+ turn of the wheels.
    Haven't had any issues under normal driving conditions...in fact..I really like them. So does the wifey!
  8. #22
    soulsea's Avatar
    soulsea is offline Cadillac Owners Enthusiast
    Automobile(s): 2016 Range Rover V8 SC ... 2015 Corvette Z06/Z07
    Nov 2012
    Mt Pleasant SC
    49
    923
    So I think the liner can be reshaped with the aid of a heat gun.
    Is agressive sanding the solution to the PAS rub?
    It looks like it's only rubbing at the inner corner.
  9. #23
    Nov 2010
    Colorado, USA
    42
    595
    Quote Originally Posted by soulsea View Post
    S -
    My plan is to try and reshape the liner with a heat gun and with regards to the PAS...i'm going to attempt to slide them back 1/4 -1/2 inch. I'm hoping that's possible as i've read on here about some that have done it. I'll explore it this weekend. I can't say for certainly that the 295/35's wouldn't have had the same problem.
    In the meantime, i'm just driving really carefully and amidst the reason snow we've had just driving a different vehicle.
  10. #24
    soulsea's Avatar
    Nov 2012
    Mt Pleasant SC
    49
    923
    Eek, sliding them back, if somehow possible, means they wouldn't line up to the edges of the fenders/q. panels ... this would result in immediate OCD implosion for me.
    If it's not that significant can't you just trim little of the plastic off the PAS at the inner corner?
  11. #25
    Nov 2010
    Colorado, USA
    42
    595
    I'm pretty OCD about that stuff myself. I'm hoping that i can move them a small enough amount that it prevents them from hitting without making it look bad.
    If I have to trim some of the plastic, then so be it.
    I'll keep y'all updated.
  12. #26
    soulsea's Avatar
    Nov 2012
    Mt Pleasant SC
    49
    923
    Thanks E ... the future of civilization rests upon your ability to make this work.
  13. #27
    Nov 2010
    Colorado, USA
    42
    595
    I'll do my best.
    soulsea and soulsea like this.
  14. #28
    Andyou75 is offline Cadillac Owners Member
    Automobile(s): 2013 CTS Coupe; 2010 Platinum Escalade ESV
    Dec 2012
    GA
    41
    17
    Sweet whip! I purchased some 24" replica wheels back in Dec Andrade the same mistake... I went with 305 instead of 285 and have been experiencing some rubbing only when fully locked. It has not been a problem for me, I adjusted my driving a little to avoid u turns etc... Never gave much thought to any sort of modifications to fix the rubbing.
  15. #29
    Nov 2010
    Colorado, USA
    42
    595
    Quote Originally Posted by Andyou75 View Post
    Andyou75 - Any longer term affects on the inner liner from the rubbing? Do you feel/hear rubbing on any compressions?
    I notice you don't have the power assisted steps. That's probably a good thing for these larger wheels.
  16. #30
    Dec 2012
    GA
    41
    17
    Elusive... I don't hear any rubbing other than during sharp turns (which I rarely do anymore). I visually check for any sign of wear today on the tires and front wheel well (did not notice any damage or signs of wear). I think you are right the absence of power running boards is a plus. Like someone mentioned before a 285 or 295 may eliminate the rub all together.
  17. Remove Advertisements
