Page 1 of 3 123 LastLast
Results 1 to 15 of 45
Thread: Busted motor mount--'07 Escalade ESV
    matthones is offline Cadillac Owners Member
    Automobile(s): 2007 Escalade ESV
    Apr 2011
    26
    All,
    Has anyone replaced a drivers side motor mount? Were you able to do it without a lift?
    Back story, I'm pretty sure it was broke before I ran out of powertrain warranty, but I couldn't get it into the shop and when I took the truck in last summer to get my brake booster replaced, they of course confirmed that the drivers side mount was broke. Dealer quoted around $800 due to the amount of work. I refuse to pay that amount on a part that never should have broke in the first place. For crying out loud my '68 GMC still has the original mounts and engine!!!
    Anyway, can anyone offer any advice on what it takes to replace to one these mounts. Thanks in advance.
    Matt
    wwceaton is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Escalade base
    Jul 2012
    50
    104
    Re: Busted motor mount--'07 Escalade ESV
    •Engine Mount Replacement - Left Side (1500 LC9/LMG/LY5/L76/L92)
    Engine Mount Replacement - Left Side (1500 w/RPOs LC9/LMG/LY5/L76/L92)
    Removal Procedure
    Notice: When raising or supporting the engine for any reason, do not use a jack under the oil pan, any sheet metal, or the crankshaft pulley. Due to the small clearance between the oil pan and the oil pump screen, jacking against the oil pan may cause the pan to be bent against the pump screen. This will result in a damaged oil pickup unit.
    1.Remove the air cleaner outlet duct.
    2.If the vehicle is equipped with four wheel drive (4WD), remove the front drive axle. Refer to Differential Carrier Assembly Replacement.
    3.Lower the vehicle.
    4.Remove the generator bracket.
    5.Remove the engine mount to frame bolts (1).
    6.Raise and support the vehicle halfway. Refer to Lifting and Jacking the Vehicle.
    7.Remove the left wheelhouse liner.
    Important: DO NOT raise and/or support the engine by the crankshaft balancer, or the oil pan.
    8.Place an adjustable (screw type) jack to the tab (1) located on the engine block.
    9.Working through the wheelhouse opening, remove the engine mount to engine bolts (1).
    10.Using the adjustable jack, raise the engine slightly until there is enough clearance to remove the engine mount.
    11.Remove the engine mount.
    Installation Procedure
    1.Position the engine mount to the engine.
    Notice: Refer to Fastener Notice.
    2.Working through the wheelhouse opening, install the engine mount to engine bolts (1).
    Tighten the bolts to 50 N.m (37 lb ft).
    3.Using the adjustable jack, lower the engine until the engine mount is sitting flush on the frame.
    4.Remove the adjustable jack from the engine block.
    5.Install the left wheelhouse liner.
    6.Lower the vehicle.
    7.Install the engine mount to frame bolts (1).
    Tighten the bolts to 65 N.m (48 lb ft) starting with the middle bolt then either side bolt.
    8.Install the generator bracket.
    9.If the vehicle is equipped with 4WD, install the front drive axle. Refer to Differential Carrier Assembly Replacement.
    10.Lower the vehicle.
    11.Install the air cleaner outlet duct.
    2007 Cadillac Truck Escalade AWD V8-6.2L
    Vehicle Engine, Cooling and Exhaust Engine Engine Mount Parts Information
    Parts Information
    OEM Part #
    Price
    Engine Mount
    Mount
    15854939
    $128.50
    Trans Mount
    15840278
    $39.63
    Labor Information
    Skill Level
    Mfg. Warranty
    Standard
    Engine Mount
    Replace
    Front Mount
    Both Sides
    B
    6.8
    9.2
    Right Side
    B
    4.6
    6.6
    Left Side
    B
    3.5
    5.4
    Rear Mount
    Apr 2011
    26
    Thanks for the reply and the information. I'm wondering if I can get away without having to take out the front axle though. I have to change the front bearing assembly in my BMW this weekend so while I have everything out I'll put the Escalade on the stands and see what kind of mess I'll be getting into.
  5. #4
    Bubblerida is offline Cadillac Owners Member
    Automobile(s): 2007 Eacalade
    Feb 2013
    34
    3
    You cannot. I work at Cadillac and had the same issue with the left front mount which is extremely common. Let the dealer change it. Request a loaner vehicle which they will supply for free
  6. #5
    kazza93203's Avatar
    kazza93203 is offline Cadillac Owners Fanatic
    Automobile(s): 07 Escalade
    Aug 2011
    30
    190
    It's possible with a couple swivels and extensions. Once the old ones out it isn't a big deal, other than starting the bolts on the new mount.
  7. #6
    Jun 2011
    33
    1
    hey matthones where u able to change the engine mount yourself just wondering mine is busted too. When they say front axle needs to be removed meaning the axle shaft or the half shaft or the complete assembly just wondering
  8. #7
    Apr 2011
    26
    jayroc,
    I have not completed this yet. I've been really busy with work and haven't even ordered the part.
  9. #8
    MRANT212's Avatar
    MRANT212 is offline Cadillac Owners Fanatic
    Automobile(s): 15 Escalade 2014 Audi S6,08 SS,88Corvette,71Corvette
    Nov 2005
    55
    408
    My motor mount went as well in my 07 ESV. I was just over 100k miles with my GMPP. Got it covered though!!
  10. #9
    Alegre323 is offline Cadillac Owners Member
    Mar 2013
    30
    my motor mount is gone aswell
    thats this weekends project
  11. #10
    Apr 2011
    26
    Alegre323,
    Did you get your project done? How did it go? Can you list out a step by time if you have the time....
  12. #11
    Sep 2010
    Houston, TX
    36
    123
    Anyone get this completed yet?
    My 2007 EXT and my neighbors 2007 Suburban both have bad LH engine mounts.
    Mine is AWD but im hoping i can get away without removing the axle/halfshaft.
  13. #12
    Sep 2010
    Houston, TX
    36
    123
    If you have AWD this is a pain.
    I did not remove the axle assembly so gaining access to the 4 bolts holding the mount to the block was a challenge.
    The heat shield around the mount adds another factor of fun into the equation.
  14. #13
    ticktock is offline Cadillac Owners Member
    Sep 2011
    Edmonton, AB (Canada)
    25
    How do you tell if its broken? My 07 has been making an intermittent clunk from the front end recently.
  15. #14
    Royalton is offline Cadillac Owners Fanatic
    Automobile(s): '09 Escalade
    Jun 2012
    Miami beach, FL
    132
    The test to check if a motor mount is gone should be the following. While stopped, Put it in drive, press down on the break pretty hard. now with the break down hit the gas hard. This should torque the engine and if a mount is bad you should basically hear and feel a slight thump.
    I have two esacalde's and In my one both motor mounts and 1 trans mount were replaced all at the same time for $1200 (1 mount was bad). I would suggest doing all 3 at once as you'll get a little break in price and the other mount will go bad pretty soon too.
    In my other lade one was bad and my warranty covered it but they did not replace the other 2 mounts as the warranty would not cover it. But the price for 1 mount replacement was $500 which was charged to my 3rd party warranty company. Both mounts that went bad were the drivers side engine mount. The mechanic said that he replaces escalade mounts all the time as they always go, and are a week link in the drive train of escalades. Hope the info helps. My suggestion is to tell them that you got a quote for $1200 for all 3 or $500 for one. Either match that price or you will take it to them.
  16. #15
    wesyder's Avatar
    wesyder is online now Cadillac Owners Connoisseur
    Automobile(s): 08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
    Mar 2009
    Eastvale Calif
    1,812
    Quote Originally Posted by ticktock
    When my driver side went I felt the clunk on accel from a stop only, i did the powerbrake test to verify. I have an 08 esv awd. Did the job myself in the driveway. Had to secure the steering wheel and remove the shaft near the mount, also removed the exhaust manifold shield unsecured the mount and used a floor jack and wood to lift the engine... I guess this is the mount that gets all the torque because this is the only one that goes bad
  • You may not post replies
