07 Escalade - Belt Squeal
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, 07 Escalade - Belt Squeal in Cadillac Escalade Forums; I have struggled with this since I have owned the truck. I have replaced all the belts, idler pulleys, and ...
    craka's Avatar
    craka is offline Cadillac Owners Member
    Automobile(s): 2007 Escalade
    Jul 2012
    19
    I have struggled with this since I have owned the truck. I have replaced all the belts, idler pulleys, and tension pulleys. I am using Gates belts. I have eliminated the squeal on the main serpentine belt. I can spray belt conditioner on the AC belt, it will stop screaming until it wears off, then start up again. Moisture or rain makes it worse. It is worse in the morning on cold starts. Any one got any solutions? I'm wondering if the AC compressor is going bad... it works great though. This is driving me crazy.
    blackex is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Cadillac Escalade Base
    Aug 2010
    Troy, Michigan
    31
    380
    Re: 07 Escalade - Belt Squeal
    You may need to replace the A/C clutch? Have a shop or mechanic take a look at it, sounds like the bearing associated with the A/C clutch may be shot and is causing your noise issue from that location.
    wwceaton is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Escalade base
    Jul 2012
    50
    104
    If the noise is only coming from the AC belt then i am sure you need to replace the small tentioner for that belt. It is a very week spring in that unit and i have replaced many for this problem. Good luck
    craka's Avatar
    Jul 2012
    19
    This will be the 2nd time I have tried a new tensioner. I am going to try a different brand belt this afternoon. I hope this fixes it. If not, I will be looking at a new compressor. This truck will be brand new by the time I'm done.
    Jul 2012
    50
    104
    If you need a new belt than try a Bando brand, this brand seems to help keep the noises away.
    craka's Avatar
    Jul 2012
    19
    I usually do not purchase Goodyear products... But their Gatorback belt stopped the squeal. Everything is working as normal.
    craka's Avatar
    Jul 2012
    19
    On the main belt (non-AC) --- I just replaced a 6 month old Dayco belt with a brand new Gates belt. The Gates belt made it two weeks and started squealing. All the pulleys feel fine and everything looks to be aligned... this is driving me crazy!
    PS - The AC belt is doing fine.
    Tec80 is offline Cadillac Owners Fanatic
    Automobile(s): DHS, 2007 ESV
    Mar 2010
    241
    If you turn the climate control off, does the squeal change? What about if you turn on the defogger? If it is worse in the first case, it could be a bad A/C clutch bearing. Otherwise, it could be the compressor itself.
    Aug 2010
    Troy, Michigan
    31
    380
    Try some wd-40 on the a/c clutch and see if that eliminates the noise for a while.
    craka's Avatar
    Jul 2012
    19
    Well, the Goodyear gatorback worked for a few months. It was raining this morning when I started the engine, then came that awful chirping/belt slipping noise. I have replaced both tensioners and idler pulley. Everything looks to be in alignment. This is about to drive me crazy. I'm tired of buying belts every 2-3 months.
    I am going to try taking the belts off and cleaning them with soap and water to see if something is on on it.[COLOR="Silver"]
    Aug 2010
    Troy, Michigan
    31
    380
    Same issue here during rainy days I hear a squeeking noise. I'm going to replace the tensioner and idler pulley to see if that cures it before I try replacing the belts.
    hrpatel17926 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 CTS, 2007 ESV
    Sep 2012
    The city of the 500
    46
    263
    Guys you can replace everything and the noise will always come back. I speak from experience. I spray the back sides of my pullies with silicone grease and it works for a month then respray.
    Jul 2012
    50
    104
    As i stated before get your self a bando brand belt and this realy does take care of the noises, Many happy customers.
  16. #14
    craka's Avatar
    Jul 2012
    19
    I will try a Bando next. I reversed the direction on my current belt and it stopped the squeal until it wears that side out. People say that means a pulley is out of line but I'm not seeing it.
  17. #15
    Aug 2010
    Troy, Michigan
    31
    380
    I will have to try this also, seems like whenever it rains I hear a belt or bearing noise but when it is completely dry out and I haven't sprayed WD40 or anything it's quiet. But as soon as I spray WD40 on the pulleys or belt the noise comes back for a few days.
  18. Remove Advertisements
