Thinking of doing the platinum front end thoughts plz
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, Thinking of doing the platinum front end thoughts plz in Cadillac Escalade Forums; THINKING OF DOING THE PLATINUM FRONT END THOUGHTS Plz Which looks better current or future front end...
    bigwill1323704's Avatar
    bigwill1323704 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 EXT
    Oct 2012
    28
    181
    murphy's Avatar
    murphy is offline Cadillac Owners Enthusiast
    Automobile(s): 2009 Cadillac Escalade Platinum
    Dec 2008
    Alberta,Canada
    813
    Re: Thinking of doing the platinum front end thoughts plz
    This works for me:
    Oct 2012
    28
    181
    Damn that's nice you win
    Lexani grill now for sale
    Btw is you r truck lowered
    Where did you get the hood
    murphy's Avatar
    Dec 2008
    Alberta,Canada
    813
    Yes it's lowered 2/3...Baer big brake kit 15f/14r, Hotchis heavy sway bars and Maggie Puffer..Oh and you can sorta pic out the ACS hood in this pic...can you see the Laser Interceptor jammer heads ?
    The hood came from http://www.acscomposite.com/hoods.html
    soulsea's Avatar
    soulsea is offline Cadillac Owners Enthusiast
    Automobile(s): 2016 Range Rover V8 SC ... 2015 Corvette Z06/Z07
    Nov 2012
    Mt Pleasant SC
    49
    923
    murphy ... which lowering kit did you use for the 2/3 and did you have any code issues with the autoride?
    @bigwill: that's a 12/13 Premium front end not Platinum, the latter isn't colormatched. And yes, 1mil x better than Lexani imo.
    Oct 2012
    28
    181
    Plz explain the premium vs the platinum front end plz
    murphy's Avatar
    Dec 2008
    Alberta,Canada
    813
    soulsea I used the McGaughy's kit. Combined with the Hotchis the two provide a taunt, balanced, stable very nice ride...much improved cosmetic stance...all with absolutely no ill effects on the magnetic ride. Air assist works perfect and since the McGaughy's comes with new dropped spindles the geometry of the front end remains pretty much stock. It looks so much better without the huge gaps above the tires to fenders
    My previous 'lade with premium front end..
    soulsea's Avatar
    Nov 2012
    Mt Pleasant SC
    49
    923
    Yeah I used to roll with a Belltech 2/3 drop once upon a time on my Tahoe Hybrid:
    I've been thinking about dropping the Esky but I keep hearing stories of the rear compressor airing up despite the shorter autoride links.
    So i was just curious if you had any issues in that regard.
    murphy's Avatar
    Dec 2008
    Alberta,Canada
    813
    Here's a couple profile shots:
    baggedlvintegra is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Escalade
    Oct 2012
    30
    120
    Premium Front End
    Platinum Front End
    Both look great and look WAY better than all that chome Strut grille look IMO. I prefer the paint matched look so I went with the Premium Front End
    Serge, not sure what you've read about the autoride links w/ compressor issues but I have 0 problems with mine and I have mine sitting exactly how I wanted it. Here is a write up I did for a guy:
    Belltech 2/3-4 Kit from “Tony”
    In order for it to sit level you need to use the 1” rear spring spacer that comes with the kit. Without it it sits about 1” lower in the rear and looks bad IMO. There are 2 tiny threaded rods for the “autoride links” that come with the kit and are 3” long. These need to be cut to 2 7/8” for it to sit level. These things control the air suspension in the rear so it affects ride height depending on the length of them. The bumpstops should be cut a little to help it keep from bottoming out the axle on the frame over big bumps
    How mine sits (about ~.25" higher in rear to give level appearance as the window trim runs downhill which if the front and rear perfectly matched is would look like the rear is sagging)
    And not to put down the mcgaughy kit but their quality has continued to be questioned and there has been several issues with their spindles, the biggest being a loss in turning radius
    Oct 2012
    28
    181
    I see what your saying so platinum is chrome grill grill and led lights correct
    36dbldz's Avatar
    36dbldz is offline Cadillac Owners Fanatic
    Automobile(s): 2010 Escalade
    Sep 2012
    The Sunshine State
    308
    With the sway bars do you have to do front & rear or just one side?
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2012 Escalade, 2014 SRX
    Apr 2003
    H.V., Pa/Town of Webb, NY
    13,289
    You would want to do the front and rear, there are no sides, that way they would be matched. I have had Hotchkis sway bars on all 11 Escalade's, they work great
  16. #14
    sdgc is offline Cadillac Owners Enthusiast
    Sep 2012
    511
    murphy....
    your ride is awsome... was it for sale once upon a time in Edmonton? i could have sworn i saw a supercharged escalade on kijiji.
    Also, is yours a platinum and supercharged, or did you change the front end, wheels and boards and lights to get it there?
    I would love to supercharge it, but dont think the wife would like it!... its her ride mostly.
  17. #15
    Apr 2003
    13,289
    Quote Originally Posted by sdgc View Post
    murphy....
    Mr M's truck is a real platinum and he had it supercharged a few months ago.
  18. Remove Advertisements
