08 Escalade ESV No Power/doors don't lock/key fob doesn't work
Results 1 to 8 of 8
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, 08 Escalade ESV No Power/doors don't lock/key fob doesn't work in Cadillac Escalade Forums; Hi Bought SUV used; came with one key, no key fobs, no manual. Bought key fobs off ebay and programmed ...
    Shello035 is offline Cadillac Owners Member
    Automobile(s): Escalade ESV
    Dec 2012
    5
    Hi
    Bought SUV used; came with one key, no key fobs, no manual. Bought key fobs off ebay and programmed them myself. Worked fine no issues
    Today I try to unlock doors with said key fobs and it won't unlock. manually unlock door with key but nothing lights up, the dash is completely dead. Door locks won't lock doors. Popped the hood to hook up jumper cables. After setting up cables the lights still do not come on when key is inserted. When door is open and keys are in the ignition I hear no door chime even with jumper cables applied to battery.
    Any ideas?
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,722
    Re: 08 Escalade ESV No Power/doors don't lock/key fob doesn't work
    Shello035, I recommend checking in with a dealership so their technicians can have a firsthand look at your concerns. I realize you most likely prefer the DIY approach instead (in which case, I hope forum members chime in soon with feedback) but please don't hesitate to contact me via email at Katie_Lucille@gmexpert.com for further assistance.
    Best,
    Katie
    Damndirtyape is offline Cadillac Owners Member
    Automobile(s): 07 Escalade EXT
    Jul 2012
    92
    Just a stab in the dark but sounds like you're not getting any power at all so perhaps the battery cables have come loose, are too corroded or otherwise damaged such that power cannot get to the truck from the battery.
    gwm247 is offline Cadillac Owners Member
    Automobile(s): 2013 XTS, 2014 SRX
    Dec 2012
    Connellsville, PA
    11
    My 07 Escalade is acting much the same way. Stranded me twice last month. Electrical system goes dead, no lights, doors don't respond to the key fob and the veh will not start. I do hear ticking in the doors when attempting to start. I've been to two dealers and they find nothing. Everything is working now but always worried it will happen again. Sorry I know this is no help for your problem, just letting you know you're not alone.
    Dec 2012
    5
    Damndirtyape and Katie, thanks for yur response. They did change the battery and everything seemed fine until last saturday. While i was driving the whole car shut down with power and started to self brake. I somhow managed to pull over and park in a parking lot but again no power anywhere so had to call a tow truck.
    gwm247 sounds like we are in the same boat! I have had it at the dealer since last Wednesday and it is running fine for them, no issues. They said it has to act up while they have it and of course nothing. have you had any other luck with yours?
    Dec 2012
    Connellsville, PA
    11
    Two weeks now since my 07 Escalade stranded me. Electrical system would not respond, wouldn't start. Only sign of life was ticking coming from the doors. Now the engine light comes on half of the time. When the engine light is on the key fob will not start the veh, need to use the key. Naturally the engine light goes off while driving to the dealership so no codes. Loved the Escalade but worried I'll get stranded again. Anyone with the same problem who has found a solution?
    cadmanchris's Avatar
    cadmanchris is offline Cadillac Owners Enthusiast
    Automobile(s): 2001 DTS,2007 STS V8
    Dec 2006
    New Jersey
    45
    601
    Just a suggestion. Have your shop/dealer do a voltage drop test across the battery cables. I had a few with ground and power cables that had high resistance. A dead giveaway to bad cables would be the clock resetting to 12:00 when it does come back up. Hope this helps someone.
    Dec 2012
    5
    Cadmanchris has the solution...it was a bad battery cable but caddie doesn't like to take car apart for this as it's expensive to replace. Exact words from service tech. But I had them do it and that is what was. Purrs like a kitten no issues now. Be prepared for some expense as my warranty didn't cover everything.
  11. Remove Advertisements
