How To: 2007 Front diff fluid change
Page 1 of 2 12 LastLast
Results 1 to 15 of 24
Like Tree6Likes
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, How To: 2007 Front diff fluid change in Cadillac Escalade Forums; All, This is my first post (I believe), but as I couldn't find any info on this after scouring the ...
    mkosharkii's Avatar
    mkosharkii is offline Cadillac Owners Fanatic
    Automobile(s): 2007 SRX4 N* MRC, 2014 Corvette Z51 3LT, 1979 KZ1000 LTD
    Sep 2011
    Norfolk, VA
    32
    230
    All,
    This is my first post (I believe), but as I couldn't find any info on this after scouring the internet, I took some pictures of my experience. I didn't cover the whole thing in pictures, but I took a few shots along the way.
    Hope this is helpful to someone!
    Tools:
    18mm socket (shallow 6-point) or wrench
    13mm socket or wrench
    Items:
    (2) qts 75w90 gear oil (I used Mobil 1, $10.99 x2 qts at Autozone)
    >2ft clear tubing
    Drain pan
    Optional:
    Hand or electric pump
    Wheel ramps
    I started by driving the front on wheel ramps. Once you crawl under the car, you will be able to identify the front differential as seen here:
    NOTE
    It is important that you remove the fill bolt prior to draining. It may be stuck, leaving you with an empty differential and no way to refill it if you start by draining.
    I sprayed some WD-40 on said fill bolt in the absence of PB blaster. If yours is as difficult as mine, and you lack a handy pipe or breaker bar, you may find the following method useful. It has worked for me in countless applications.
    As seen above, simply use a large wrench around the end of your ratchet handle. The benefit is twofold; greater leverage and accommodating angle.
    Once the fill bolt is removed, position your drain pan appropriately and remove the drain bolt, as identified below:
    Your drain bolt may look something like this:
    Make it look like this:
    Once the diff is finished draining, reinstall the drain bolt and tighten.
    To refill, I strongly suggest you acquire a pump of some sort. I punctured my first bottle by trying to simply squeeze directly in to the fill hole. I then ended up taking a small length of plastic hose and running it from the fill hole up to the area between the fender and engine. I simply twisted the hose on to the tip of the gear oil bottle, turned it upside down, punched a hole in the bottom, and let gravity do the rest. This method is PAINFULLY slow, to the tune of well over an hour. GET A PUMP!
    At somewhere between 1.5-2 qts, you should be level with the bottom of the fill hole. You can periodically check the level by using your finger as a dip stick.
    Once you are satisfied with the level, set your remaining oil aside, reinstall the fill bolt, and tighten.
    Done!
    K9Caddy is online now Cadillac Owners Connoisseur
    Automobile(s): 2009 AWD Escalade Ultra Luxury Raven Black
    Oct 2009
    Illinois
    38
    1,518
    Re: How To: 2007 Front diff fluid change
    Very nice write up!!
    Mods: Sticky please.
    2007caddy is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac Escalade 07
    Nov 2008
    Toronto, Canada
    382
    I second that...
    jdubh25's Avatar
    jdubh25 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 CTS, 2007 Escalade
    Jan 2012
    San Diego, CA
    141
    Funny, last night I was on YouTube trying to figure out how to do this...thanks for the info!!!
    mkosharkii's Avatar
    Sep 2011
    Norfolk, VA
    32
    230
    Quote Originally Posted by jdubh25 View Post
    And the night before I was doing the same thing...
    Anyway, I'll be moving on to the rear diff next. That will be followed by spark plugs, transfer case, transmission fluid exchange, trying to hunt down an annoying squeak in the rear suspension when it's compressed a certain way, and perhaps a brake flush. Those will be done in no particular order.
    Please let me know if any of these are of interest, or better yet if you've done them and can provide insight.
    48Dodge is offline Cadillac Owners Fanatic
    Automobile(s): '08 Escalade ESV
    Mar 2011
    41
    442
    I actually just bought fluids a couple days ago for doing the diffs, transfer and tranny. Seeing this will help spur me into doing it.
    BlownEscalade is offline Cadillac Owners Fanatic
    Automobile(s): '11 Escalade, '06 Escalade
    Jun 2006
    Edmonton, Alberta, Canada
    221
    do you have to add any additives to the gear oil? My old 06 I had to add LSD additive to the gear oil
    SouthernCaddy's Avatar
    SouthernCaddy is offline Cadillac Owners Fanatic
    Automobile(s): Escalade ESV
    Jan 2010
    Ellerslie, Georgia, United Sta
    52
    275
    after you do the spark plugs let me know how you feel. I am really interested in the rear plug on the passenger side. What a pain in the ass that was!! Aleast for me with no lift!
    MrHolland's Avatar
    MrHolland is offline Super Moderator
    Automobile(s): 2010 Platinum Escalade, 1996 Fleetwood Brougham
    Jul 2010
    Midwest
    5,685
    Thank you for this write up. Very informative!! Its been added to the Sticky at the top of the page.
    Mar 2011
    41
    442
    Quote Originally Posted by SouthernCaddy View Post
    That plug was no fun. I actually dropped one in the process so I had to get another one. I think I could replace it pretty quickly now but of course it's not needed for at least 50k
    Gunnar75 is offline Cadillac Owners Member
    Automobile(s): 07 Escalade ESV
    Nov 2012
    5
    Thank you! What fluid did you use and at what mileage interval are you using?
    alex29573 is offline Cadillac Owners Member
    Automobile(s): 2008 Escalade
    Sep 2012
    30
    26
    interested in the tranny and transfer case oil change!!
    Mar 2011
    41
    442
    Front diff done today. Extremely easy. If you can change your own oil, you can definitely do this. Removing the fill bolt was the hardest part, had to use a hot wrench for a little bit and it popped loose. Luckily just needed my MAPP torch and not my oxyacetyl. Ended up putting nearly all of the 2qts back in, about an inch of oil left in one bottle. Rear diff next, then transfer and eventually the tranny
  16. #14
    Alberta is offline Cadillac Owners Member
    Automobile(s): 2008 Escalade ESV
    Mar 2010
    Calgary, Ab.
    11
    What is a "hot wrench"?
  17. #15
    cadmanchris's Avatar
    cadmanchris is offline Cadillac Owners Enthusiast
    Automobile(s): 2001 DTS,2007 STS V8
    Dec 2006
    New Jersey
    45
    601
    Quote Originally Posted by Alberta
    A torch
  18. Remove Advertisements
