Engine won't shut off on 2008 Cadillac Escalade ESV
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 22
Like Tree1Likes
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, Engine won't shut off on 2008 Cadillac Escalade ESV in Cadillac Escalade Forums; For the second time I got to work put my truck in park took the key out and my engine ...
    Hfresh's Avatar
    Hfresh is offline Cadillac Owners Member
    Automobile(s): 2008 Escalade ESV
    Jul 2011
    26
    For the second time I got to work put my truck in park took the key out and my engine kept running. Does anyone have any idea or has anyone experienced this.
    Kingoftypos is online now Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    37
    9,149
    Quote Originally Posted by Hfresh
    Even though your in the wrong area. I'll be able to help. If this happens again, play around with the ignition switch with the key out. Hopefully it'll turn off. It may just be the contacts are still making contact. Which should be covered under your warranty, depending on where you stand with it.
    Also, how heavy is your key chain? Yours and anyone else who has a set of keys. I ask, because if it's too heavy it will cause the above to happen. In my section, 1st gen CTS. We've had quite a few people complain about their cars dying. One of then pointed out that their girl friend has a heavy set of keys. So took the braveness away and all went well.
    KOT
    Hfresh's Avatar
    Jul 2011
    26
    I got it to shut off after three hours running. I called my friend who is a mechanic he told me to remove the ignition switch fuse. It shut off after that I'm off to the dealership in the morning to find out whats the deal.
    Rolex's Avatar
    Rolex is offline Super Moderator
    Automobile(s): 2008 Nissan Titan, 1996 Jeep Wrangler
    Arkansas
    41
    12,033
    Re: Engine won't shut off on 2008 Cadillac Escalade ESV
    to the Escalade forum.
    The above post is my 2 cents....nothing more.
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2012 Escalade, 2014 SRX
    Apr 2003
    H.V., Pa/Town of Webb, NY
    13,280
    Did you try putting the key back in and moving it to run then off again?
    K9Caddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 AWD Escalade Ultra Luxury Raven Black
    Oct 2009
    38
    1,464
    I've heard of that issue with "bad" gas. Try using a different station and of course, premium.
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,674
    Quote Originally Posted by Hfresh View Post
    Hfresh, I hope you'll let us know what the outcome is after consulting with your dealership! If you'd like me to contact them at any point on your behalf, just drop me an email at Katie_Lucille@gmexpert.com.
    Best,
    Katie
    mikemjohnson is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Escalade, 2006 CTS-V
    Jan 2009
    173
    Quote Originally Posted by K9Caddy View Post
    not going to be gas related; bad gas will only cause performance issues, not "over performance" hah
    Quote Originally Posted by Kingoftypos View Post
    KOT
    you have no idea how often i take calls for keys not working in the cylinder; not turning or hard to get out. first thing i do when the client arrives is ask for the keychain. 94.3929% of the time its a lady with about 4 pounds of stuff on her key chain. results in a ignition cylinder being needed (this is on german stuff, a lot of VWs are common for this failure). not saying thats what caused this in the OP's situation, but just a piece of advice for everyone
    nate6966 likes this.
    Hfresh's Avatar
    Jul 2011
    26
    I usually use Mobil gas but I went to a BP gas station. Both times this has happened its been with BP gas.
    Hfresh's Avatar
    Jul 2011
    26
    I don't have a heavy key ring. I don't want all that bulk in my pocket. Mainly the key and the key fob are the only thing in my ignition when I drive. I have a key ring that separates and my house keys are on the other half.
    AWallerJr's Avatar
    AWallerJr is offline Cadillac Owners Member
    Feb 2012
    27
    How can bad gas keep the truck running after the key is out the ignition??
    Oct 2009
    38
    1,464
    It's called "dieseling". Here are some causes that were copy and pasted, in most cases it happens in older carbureted engines.
    Dieseling can occur for several reasons:
    Built-up carbon in the ignition chamber can glow red after the engine is off, providing a mechanism for igniting unburnt fuel. Such a thing can happen when the engine runs very rich, depositing unspent fuel and particles on the pistons and valves. Similarly, rough metal regions within the piston chamber can cause this same problem, since they can glow red. It has also been suggested that an improperly rated spark plug can retain heat and cause the same problem.
    A carburetor that does not completely close can contribute to running once the engine is off, since the extra fuel and oxygen mixture can combust easily in the warm piston chamber. Similarly, hot vaporized oil gases from the engine crankcase can provide ample fuel for dieseling.
    Incorrect timing.
    An engine that runs too hot or too lean may produce an environment conducive to allowing unspent fuel to burn.
    An idle speed that is too fast can leave the engine with too much angular momentum upon shutdown, raising the chances that the engine can turn over and burn more fuel and lock itself into a cycle of continuous running.
    AWallerJr's Avatar
    Feb 2012
    27
    Wow... Thanks for the info
  16. #14
    Hfresh's Avatar
    Jul 2011
    26
    Thanks for the info. People thought I didn't know what I was talking about. My Caddy has never done that until I got gas at this certain gas station. Two times with the same gas at the same exact station. There is no way it can be a coincidence.
  17. #15
    Nice Ride is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 ESV Platinum / 2013 SRX Premium
    Jan 2012
    1,244
    Highly unlikely it's the gas. Does it run smooth as if the key is still in? Or is it a little rough? Any lights lit on the dash? Have you tried using your other key for a while?
  18. Remove Advertisements
