Power running boards and 26" rims?
Results 1 to 11 of 11
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, Power running boards and 26" rims? in Cadillac Escalade Forums; I think I read something on here years ago about problems with 26" rims on escalade's with power running boards ...
    black escalade is offline Cadillac Owners Member
    Nov 2010
    20
    I think I read something on here years ago about problems with 26" rims on escalade's with power running boards but I can't seem to find anything now. So, are we able to safely ride on 26" rims without rubbing or do we need to make any modifications? Also, does anyone know what the safe offset/backspace is for 26x10 rims?
    Thanks in advance.
    prosseda is offline Cadillac Owners Member
    Automobile(s): 2007 Escalade EXT 2009 Platinum ESV
    Aug 2006
    91
    30 to 35 offset. There are Allen bolts you can loosen to slide the boards for clearance.
    BEarle is offline Cadillac Owners Enthusiast
    Automobile(s): 2010 Cadillac Escalade
    Dec 2011
    30
    671
    Mine still rub like hell on the running boards. I'll check that out about the Allen bolts though.......
    Nov 2010
    20
    Re: Power running boards and 26" rims?
    Thanks prosseda.
    If there would be any rubbing, where would it usually take place? Front or rear?
    What are the problems in running a lower offset like around +10-15mm?
    MrHolland's Avatar
    MrHolland is offline Super Moderator
    Automobile(s): 2010 Platinum Escalade, 1996 Fleetwood Brougham
    Jul 2010
    Midwest
    5,658
    My factory 22 rubbed the inner fenders on mine when I picked it up.
    Dec 2011
    30
    671
    They rub in the front when you turn the wheel. It actually ended up rubbing some of the running board off.
    Aug 2006
    91
    Quote Originally Posted by black escalade
    Thanks prosseda.
    The lower offset makes the arc the tire pivots on longer. So then the tire can rub with even less steering angle. If a 30 offset just clears the inner fender, imagine a 15 trying to compress your tire that extra 15mm by using your inner fender. A properly inflated tire doesn't even compress that much with the weight of the vehicle on it. So you would end up with the complete force of your power steering pushing on your fender.
    Nov 2010
    20
    The size of rims I'm looking at only comes in a 26x10 with a +25mm offset. 305/30 tires. I was playing around measuring earlier and am pretty confident I will have rubbing issues with the running boards. Will I have issues with the inner fenders? If so, is there anything I can do to prevent it?
    Recovery21's Avatar
    Recovery21 is offline Cadillac Owners Member
    Automobile(s): 2011 Escalade EXT, 1996 Fleetwood Brougham (Sold)
    Jul 2012
    Buffalo NY
    57
    I know a sawzall will work for that! I had 35" tires on my H3t and I ran into the problem of them rubbing the inner fender. I took a sawzall to them and fixed the problem. I know my stock 22's are close to rubbing when I lock the steering to the right. But if you get the right size tire and offset, there should be no issues. If the new tires sit taller than the stocks, they will rub when you make a sharp enough turn.
    Nov 2010
    20
    Guess I'll find out once I get the rims mounted...I can live without turning the wheel all the way, but having the running boards hit on a light turns is a different story.
    patrykkoul is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jul 2007
    16
    The power running boards are adjustable to move back. I'm not sure if they were on all years, but I just picked up my 2012 and the dealer moved the power boards back for me so the 26s wouldn't rub. I'm running 295 width tires though and I have a 2/3 drop and it doesn't rub at all. Only when I crank it in reverse it will rub on the plastic inner fender wall. When I had my Denali it rubbed there too with the same set up, but after a couple months it stopped because the tired rubbed away the plastic. I haven't had any problems with it regarding the running boards though.
  14. Remove Advertisements
