cadillac
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Cadillac Technical Archive | Cadillac Dealers | Cadillac Reviews | Cadillac Dealer Reviews | Cadillac Vendors | Decals
gm social network
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Like Tree2Likes
Cadillac Escalade, EXT and ESV Forum - 2007+ Discussion, Need new plugs & wires? in Cadillac Escalade Forums; 2008 ESV, about 51,000 miles, use good gas but who knows what crap you get sometimes. So, do you think ...
    DRBLING is offline Cadillac Owners Member
    Automobile(s): NONE
    Dec 2010
    62
    30
    So, do you think the factory plugs & wires should be changed even though it runs well? I have noticed my mileage recently a little less than before, and I do drop in fuel system cleaner 3 or 4 times a year.
    If so, which plugs / wires do you suggest? NGK and stock wires maybe?
  2. Cadillac Network Advertisements Registered members do not see these ads. Click here to remove them.
    Always
    2010
    Many
    48548m is offline Cadillac Owners Fanatic
    Automobile(s): EXT
    Sep 2011
    37
    165
    I put a set of magnacores on my new 11.... Much bigger than stock. I do like ngk or stock plugs though. On the womans g8 I put new plugs and wires at 59000. I only did it because it is a dd and 4 years old... In my eyes no point to be cheap. But the plugs didn't look to bad. Don't know what to say. Can't hurt but might not help.... Maybe seafoam would be better.
    mrholland's Avatar
    mrholland is offline Cadillac Owners Enthusiast
    Automobile(s): 2010 Platinum Escalade, 1996 Fleetwood Brougham
    Jul 2010
    37
    877
    Re: Need new plugs & wires?
    With the technology we have today and the computers in the cars, I'm not sure that there is a reason to use something other than stock when it comes to plugs and wires. 1. Its not a race car. 2. Current day engines are designed to burn clean. You have 50,000 miles on your current set, I don't think changing them to a more expensive after market set will really allow any more mileage than you've already driven. GM warranties their engines to 100,000 miles with the parts it came with from the factory. They believe in that combination, why shy away from it if its just a daily driver? I do believe there are areas that one can improve, on a bone stock factory engine, I don't think plugs and wires are it. JMHO...
  5. Sponsored Cadillac Advertisements (Supporting Members don't see these ads)
    ELUSIVE is offline Cadillac Owners Fanatic
    Automobile(s): 2010 Escalade ESV, Porsche 997 Carrera S, Audi A4 Avant 2.0T
    Nov 2010
    Colorado, USA
    261
    Quote Originally Posted by mrholland View Post
    +1. Well written.
    mrholland's Avatar
    Jul 2010
    37
    877
    Thank you
    Automobile(s): NONE
    Dec 2010
    62
    30
    Appreciate your points. I'll probably pull a few plugs and see how they look. I bought the ESV from a good Caddy dealer last year when it had around 45,000 miles. Now at 51,000 miles. So now I just figure no telling what junk gas may have been used so maybe it does need new plugs & maybe wires just for overkill.
    It runs fine but I have noticed my mileage not quite what it was from a while ago.
    Tks. again.
    quattrotman's Avatar
    quattrotman is offline Cadillac Owners Fanatic
    Automobile(s): 07 Escalade EXT
    Jul 2011
    Vancouver BC
    41
    222
    I agree. I wouldn't change that stuff out unless I had a noticeable problem. If your gas mileage is down, maybe the plugs could use a change but probably won't make much difference unless they are really bad. Nowadays, that stuff is meant to be an item that gets changed once, maybe twice in a vehicle's life. I see no value in changing that stuff on a new vehicle as there will be little to no improvement.
    Nov 2010
    Colorado, USA
    261
    Also, if your mileage is down have you:
    1) Check your tire pressures and treadwear?
    2) Checked your air filter?
    3) Started using different gas?
    4) Changed your driving style?
    Of all the variables that could reduce your gas mileage on a car with only 51,000 miles I would say plugs and wires are very unlikely to cause a reduction.
    cadmanchris's Avatar
    cadmanchris is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Cadillac DTS, 2007 Escalade ESV
    Dec 2006
    New Jersey
    40
    397
    As long as you do not have any misfires, your plugs and wires should be fine. Plugs are good up to 100k.
    48Dodge is online now Cadillac Owners Fanatic
    Automobile(s): '08 Escalade ESV
    Mar 2011
    36
    251
    I replaced my plugs at 100k. I'm fairly certain they were original equipment and the wear on them was pretty minimal. If you do decide to replace them, set aside a good afternoon for it. Driver side plugs go pretty quickly. Passenger side are a different story.
    mstymntntop is offline Cadillac Owners Member
    Automobile(s): Blue Chip Escalade
    Aug 2011
    North Carolina
    31
    34
    Anyone have any tips as to how to get out and replace the plug that is closest to the firewall on the passenger side? I had everything setup to remove the plug but p***ed out because I didn't know if I could get the new plug in.
    Ghost Deany is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 Escalade, 2005 CTS
    Nov 2007
    NJ
    27
    524
    Quote Originally Posted by mstymntntop View Post
    Get it from underneath the truck. Its easy. The higher you can jack the front of the truck up the better. If you had a lift you could probably change it in 3 mins.
    Mar 2011
    36
    251
    I jacked it up, removed the wheel and then the inner liner. The front 3 really aren't too bad. The rear was pretty tough even with a wobble extension.
  16. #14
    Aug 2011
    North Carolina
    31
    34
    That sounds like a good plan. Do you all use jack stands? I'm thinking about getting some since we are one of the locations where Sears is closing. Great discounts so far....If you do have them, which size (2, 3, or 4 ton) are you comfortable being underneath?
  17. #15
    CStradling24 is offline Cadillac Owners Member
    Automobile(s): 2005 STS, 2008 Escalade EXT
    Apr 2009
    United States
    24
    93
    I have 2, 2.5 ton stands I believe
Sponsored Cadillac Ads - Click here to show your support and REMOVE advertisements!
  • You may not post replies
Read about Cadillac ATS | Cadillac ATS Forum | Lincoln | Buick | Hyundai Genesis Forum | Kia Forte Forum
custom floor mats | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | Cadillac Chrome and Black Chrome Wheels | window tinting
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239
