cadillac
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Cadillac Technical Archive | Cadillac Dealers | Cadillac Reviews | Cadillac Dealer Reviews | Cadillac Vendors | Decals
gm social network
Results 1 to 14 of 14
Like Tree2Likes
  • 1 Post By hcooperrn
  • 1 Post By cadmanchris
Cadillac Escalade, EXT and ESV Forum - 2007+ Discussion, Climate Control Temperature Issue in Cadillac Escalade Forums; hi, i have an 07 Escalade ESV and my climate control temperature has an issue. even if i put the ...
    Cyberman is offline Cadillac Owners Member
    Automobile(s): 2007 Escalade ESV
    Jul 2011
    29
    hi, i have an 07 Escalade ESV and my climate control temperature has an issue. even if i put the temp setting to 76 hot air doesn't come from the vents. for some reason it doesn't want to heat up the car anymore. haven't tried the ac temps. is it my thermostat? if so how accessible is it to change it myself?
    thanks
  2. Cadillac Network Advertisements Registered members do not see these ads. Click here to remove them.
    Always
    Many
    48Dodge is online now Cadillac Owners Fanatic
    Automobile(s): '08 Escalade ESV
    Mar 2011
    36
    251
    Re: Climate Control Temperature Issue
    Heat usually comes from the floor vents unless you switch it off auto. Is the fan not blowing at all, making any noise?
    mrholland's Avatar
    mrholland is offline Cadillac Owners Enthusiast
    Automobile(s): 2010 Platinum Escalade, 1996 Fleetwood Brougham
    Jul 2010
    37
    877
    Does the radiator have coolant in it?? I know, its an ignorant question but I had to ask. You might be surprised to hear that Ive seen this before. Someone was having issues with odd temp readings and the heater not working well during the winter.
  5. Sponsored Cadillac Advertisements (Supporting Members don't see these ads)
    Jul 2011
    29
    Quote Originally Posted by 48Dodge View Post
    we don't usually have it on auto. when you play with the fan speed it switches off auto.
    yes the fan is blowing, everything sounds normal.
    lemme go play around with it some more, maybe i missed something.
    i will report back...
    Quote Originally Posted by mrholland View Post
    i am assuming it does :-) lemme check
    Jul 2011
    29
    just checked again, no matter how high i set the temp, it does NOT blow hot air. could it be a thermostat issue? are there any fuses i can check?
    Jul 2011
    29
    ok, just checked engine coolant level, it is more than 1 inch below the line where it needs to be filled to. could that be the cause? i will get some dex-cool coolant tomorrow and see
    Jul 2011
    29
    just filled the coolant to the proper level. i don't think it changed anything.
    i am assuming it is a thermostat issue. where is the thermostat located?
    hcooperrn is offline Cadillac Owners Member
    Automobile(s): 2007 EXT
    Feb 2010
    34
    3
    Are you asking about the engine thermostat? If your engine came up to normal operating temperature on your dash gauge, and didn't overheat or stay abnormally cool, then it isn't your engine thermostat. I could see it being a problem with the temperature sensor if you were using Auto, but if you aren't getting heat in manual control, I would look into the blend doors first, plugged heater core next. That's just my general approach, I haven't been inside my dash yet to know if it is different from other vehicles I've worked on.
    RippyPartsDept likes this.
    Jul 2011
    29
    Quote Originally Posted by hcooperrn View Post
    how can i test for blend doors? order a new one and see if that takes care of problem? is it fairly easy access?
    where is the heater core?
    just to clarify the temperature of the air that comes out of the vents is pretty much like room temp, not cold or hot even if the temp is set to 75-80F, could it still be the blend doors?
    cadmanchris's Avatar
    cadmanchris is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Cadillac DTS, 2007 Escalade ESV
    Dec 2006
    New Jersey
    40
    397
    Sounds like you may have an issue with the temp actuators. If you set the passenger side to 90 degrees,do you get warm air? If you do, then the driver's temp actuator may be bad. You may have to have the truck scanned for codes in the hvac control module.
    Jul 2011
    29
    Quote Originally Posted by cadmanchris View Post
    went shopping today and noticed something odd. when i started the car temp was set at 75F, after driving for a bit it was still blowing cool air. but when i increased the temp to 80F i felt warm air for about 5 min but then it started cooling down again. what's going on here?
    i haven't tried your test yet
    Jul 2011
    29
    just tried your test, it seems to be working ALL AROUND at 90F. tried the passenger side first, it blew hot air at 90F continuous. then i tried 90F on both sides, and they both worked. as soon as i lowered the temp to 80F temp dropped and started blowing cool air again. HELP!
    Dec 2006
    New Jersey
    40
    397
    Each duct has a temp sensor, and one may be reading the incorrect temp or the in car temp sensor may not be reading the correct temp. The best thing is to have it scanned and have the parameters checked. It may be something simple as an in car temp sensor. If it thinks the truck is 90 degrees inside, it will try to cool the truck down inside. 90 degrees is a default to full heat, regardless of the temp inside. Are you in tri state?
  16. #14
    Jul 2011
    29
    wish i was in the tri-state, i'm in CA. i guess i need to take it to the dealer? i try to avoid them like the plague, they have a very bad attitude. every time i'm there i get into an argument with them :-)
Sponsored Cadillac Ads - Click here to show your support and REMOVE advertisements!
  • You may not post replies
Read about Cadillac ATS | Cadillac ATS Forum | Lincoln | Buick | Hyundai Genesis Forum | Kia Forte Forum
custom floor mats | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | Cadillac Chrome and Black Chrome Wheels | window tinting
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239
