2008 Escalade Mildy Rough Idle
Results 1 to 12 of 12
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, 2008 Escalade Mildy Rough Idle in Cadillac Escalade Forums; My 2008 has a mildy rough idle at the current idle speed RPM of 550-600 RPM. I note that a ...
    bigmac11 is offline Cadillac Owners Member
    Automobile(s): Escalade
    Aug 2011
    66
    22
    My 2008 has a mildy rough idle at the current idle speed RPM of 550-600 RPM. I note that a small increase in idle speed of 50-100 RPM or so smooths the idle considerably. Is this an adjustment that the dealer can / will make? Any downside?
    2007caddy is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac Escalade 07
    Nov 2008
    Toronto, Canada
    382
    Re: 2008 Escalade Mildy Rough Idle
    Could be a series of things, has your throttle body been cleaned, what's the mileage on your vehicle....also something as simple as a clogged filter could cause the issue...I clean my TBs on all the trucks I ever owned once per year and I do see a difference in the idle...good luck
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2012 Escalade, 2014 SRX
    Apr 2003
    H.V., Pa/Town of Webb, NY
    13,280
    Miles on truck?
    Mike06train is offline Cadillac Owners Member
    Sep 2011
    Delco,Pa
    76
    My first though is the throttle body (as stated by 2007caddie) or dirty injectors.
    Apr 2003
    13,280
    Yep clean the t-body, dump a bottle of Techron, and then every 5k miles, run good gas, check air cleaner filter, all good things.
    K9Caddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 AWD Escalade Ultra Luxury Raven Black
    Oct 2009
    38
    1,464
    Clean the MAF too.. They make a special cleaner for it and it's available at your local parts store. Very easy to do...
    48Dodge is offline Cadillac Owners Fanatic
    Automobile(s): '08 Escalade ESV
    Mar 2011
    41
    442
    Quote Originally Posted by K9Caddy View Post
    That's the one thing I still need to do. I have a can of the MAF cleaner on my shelf, just keep forgetting to do it. Cleaning the TB was the biggest fix for my idle "bump" and mileage. I had a pretty smooth idle, but about every 10 seconds or so, there'd be a little bump to it. I still get an occasional extremely subtle bump after cleaning, but I only notice it because I'm looking for it.
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,674
    The dealer will definitely be able to diagnose and/or repair this issue for you. If you would like me to make an appointment at you local dealer just let me know.
    Breanne
    Mar 2011
    41
    442
    Quote Originally Posted by 48Dodge View Post
    Just cleaned the MAF last night. I've only driven the truck a few miles in town and haven't really paid attention to the idle other than when I put everything back together. It seems like it's running smoother now.
    Braknglases07 is offline Cadillac Owners Member
    Automobile(s): 07 escalade EXT
    Jan 2009
    Reunion, FL
    32
    61
    Nothing the dealer does is going to fix this problem it is something serious about this engine. I have clean the throttle body, new air filter, clean MAF, run 93 octane and put
    techron in once a month, changed plugs and wires, been into the dealer countless times they say its normal because its such a big and powerful engine, cam shaft sensor was replaced did nothing. I even bought a diablo sport tuner to see if it would correct the timing and still has the same rough idle, feels like its going to stall. My family has 3
    escalades mine an 07 parents are 08 and 11.
    bigirb2002 is offline Cadillac Owners Fanatic
    Automobile(s): 05 escalade
    Mar 2013
    31
    119
    I had to chime in on this old thread. The behavior is normal. The lean idle mixture causes this. U can tune this out by enriching the idle air fuel ratio but why do that ur wasting more gas. I am a tuner. Trust its hurting nothing. That idle usually starts to feel rough around 16afr and up. There is something u can do to help it. Run ethanol free gas but good luck w that it's really not worth it
    Apr 2003
    13,280
    This is NOT normal, I have had a dozen of these trucks and none idle rough with tuning, you may need to increase the idle rpm by 100 or so rpms because they are a little low stock, but it idles like my benz
  15. Remove Advertisements
