Which 12v switched wire should I tap into for Bluetooth accessory power?
Results 1 to 8 of 8
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, Which 12v switched wire should I tap into for Bluetooth accessory power? in Cadillac Escalade Forums; I'm installing a parrot bluetooth into my wifes 2007 escalade. For accessory power, I've been reading on this forum I ...
    GrandmasTeeth is offline Cadillac Owners Member
    Automobile(s): 2007 Escalade
    Aug 2011
    I'm installing a parrot bluetooth into my wifes 2007 escalade. For accessory power, I've been reading on this forum I should tap into a brown wire that powers the passenger mirror. I was told it is on the right side of the dash. When testing with a test light, I found 2 pairs of brown wires had switchable power. So my question to all of the folks that have done this before, which wire or pair should I tap into? See attached pic.
    Thank you in advance for your advice.
    CStradling24 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS, 2008 Escalade EXT
    Apr 2009
    United States
    29
    113
    Re: Which 12v switched wire should I tap into for Bluetooth accessory power?
    Did you find out the answer?
    Tranzor is offline Cadillac Owners Member
    Automobile(s): 2007 Escalade Esv
    Dec 2011
    38
    20
    Quote Originally Posted by GrandmasTeeth View Post
    which wire did you end up using? I need to find a 12v switched wire as well and I'm considering using wich ever one you used so long as it worked out good. thanks
    txlaw2002 is offline Cadillac Owners Member
    Automobile(s): 2008 Escalade
    Feb 2008
    San Antonio, Texas
    23
    I would also like this answer since i want to install a parrot mk9200. I placed the "brain" behind the passenger side dash on the passenger side but I'm uncertain about which wire to tap. thx
    TabletDash's Avatar
    TabletDash is offline Cadillac Owners Member
    May 2013
    Fort Lauderdale, FL
    33
    10
    Me too. Tried a brown wire under the ignition with no luck
    CaMs is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jun 2007
    69
    looking to hook hardwire by DVD headrest. Found this video of a tahoe. Should these work in our trucks?
    http://www.youtube.com/watch?v=zb_ZuA-z-Rs
    Look at the 7min mark. Looks like he is tapping into the same wires as the OP mentioned?
    Jun 2007
    69
    Does anyone have the schematics on what the above(in video and OP pic) wires are for. In the video hes talking about a couple of brown wires on the pass side box.
    Jun 2007
    69
    Anyone? Or Where can I get a service manual to see for myself?
  11. Remove Advertisements
