Want the 2-way remote start key fob....could I just buy and program?
Results 1 to 8 of 8
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, Want the 2-way remote start key fob....could I just buy and program? in Cadillac Escalade Forums; Hi all, Would buying the 2-way remote be as simple as programming it w/ my Escalade? Or would I have ...
    BlackDynamiteCaddy is offline Cadillac Owners Member
    Automobile(s): 2008 Escalade
    Oct 2011
    9
    Hi all,
    Would buying the 2-way remote be as simple as programming it w/ my Escalade? Or would I have to have the dealer install this?
    MrHolland's Avatar
    MrHolland is online now Super Moderator
    Automobile(s): 2010 Platinum Escalade, 1996 Fleetwood Brougham
    Jul 2010
    Midwest
    5,657
    Re: Want the 2-way remote start key fob....could I just buy and program?
    I believe there are different types of remotes, but once you get the proper one for your car I believe then you can program it. Heres some info from another post-
    http://www.cadillacforums.com/forums...-key-fobs.html
    prosseda is offline Cadillac Owners Member
    Automobile(s): 2007 Escalade EXT 2009 Platinum ESV
    Aug 2006
    91
    The display will not work unless you install the additional module that goes the the 2-way remote.
    murphy's Avatar
    murphy is offline Cadillac Owners Enthusiast
    Automobile(s): 2009 Cadillac Escalade Platinum
    Dec 2008
    Alberta,Canada
    813
    You must have the dealer install and program. I purchased it for my '07 and regretted it. Range was only so so better..two way was nice but it was costly and the remote is fairly large. You can do better with the aftermarket units out there which will also not limit you to only two starts.
    MrHolland's Avatar
    Jul 2010
    Midwest
    5,657
    I'm sorry I wasn't thinking when you said two way remote. My misunderstanding, I was thinking regular fob.
    davidmalky is offline Cadillac Owners Member
    Oct 2013
    1
    I just purchased a set of 2 upper-class key-less remotes from ebay from seller named "remotes.inc". for my 07 escalade.
    cheapest price around and has fantastic service.
    his rating is way up there presumably because others are having the same great experience. was able to program in under a minute.
    would recommend to all
    thank you so much and keep up the good work
    here is the link to the ebay item http://www.ebay.com/itm/300914349897...84.m1497.l2649
    wesyder's Avatar
    wesyder is online now Cadillac Owners Connoisseur
    Automobile(s): 08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
    Mar 2009
    Eastvale Calif
    1,802
    Quote Originally Posted by davidmalky
    I just purchased a set of 2 upper-class key-less remotes from ebay from seller named "remotes.inc". for my 07 escalade. cheapest price around and has fantastic service. his rating is way up there presumably because others are having the same great experience. was able to program in under a minute. would recommend to all thank you so much and keep up the good work <img src="http://www.cadillacforums.com/forums/attachment.php?attachmentid=154914"/> here is the link to the ebay item www.ebay.com/itm/300914349897?ssPageName=STRK:MEWNX:IT&_trksid=p398 4.m1497.l2649
    those are nice, i will be acquiring some in the near future
    pinoyfiend is offline Cadillac Owners Member
    Oct 2013
    5
    +1 on the upper class keyless remotes. Also got them from ebay seller "remotes inc". Got them in two days and programmed in 5 minutes...
  11. Remove Advertisements
