ESV Wouldn't Start!!
Results 1 to 6 of 6
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, ESV Wouldn't Start!! in Cadillac Escalade Forums; I stopped to get gas. When I tried to start it the key just turned and the lights went out ...
    krieghoff is offline Cadillac Owners Fanatic
    Automobile(s): ESV
    Dec 2009
    361
    I stopped to get gas. When I tried to start it the key just turned and the lights went out but it didn't do anything.
    On the 3rd try it started. When I got home I tried it twicw and it started ok.
    Has this happened to any of you?
    Thanks for help in advance!
    hdmech is offline Cadillac Owners Member
    Automobile(s): 2007 escalade , 87 GN
    Apr 2010
    Toronto
    55
    38
    Re: ESV Wouldn't Start!!
    This happened to me a few times and after reading some threads on the forum alot of owners have discovered problems with the factory crimp on the battery terminal cables. It's kind of hard to diagnose because visually they look fine but the crimp can be weak and the connection becomes compromised. Luckily I discovered mine because mine did the exact same thing at a fuel stop , I got out and twisted the ground cable on the battery side and it started up. The positive side can do the same it causes all sorts of warnings and error messages to go off as well if the connection gets interrupted as your driving down the road. Hope this helps.
    SouthernCaddy's Avatar
    SouthernCaddy is offline Cadillac Owners Fanatic
    Automobile(s): Escalade ESV
    Jan 2010
    Ellerslie, Georgia, United Sta
    52
    275
    Yep that is where I would start
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2012 Escalade, 2014 SRX
    Apr 2003
    H.V., Pa/Town of Webb, NY
    13,289
    As said could be a battery issue, cable issue, have seen issues when not 100% in park, looks like it's in park but a touch of the shifter would allow starting.
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,697
    I would start there as well. Your local GM dealer will be able to diagnose this for you as well. Keep us updated.
    Breanne
    Automobile(s): ESV
    Dec 2009
    361
    I am going to work on it today and see what I can find. I hope it so I don't have to worry about.
    Thanks guys
  9. Remove Advertisements
