? about Platinum headlamp adjustment screw
Results 1 to 4 of 4
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, ? about Platinum headlamp adjustment screw in Cadillac Escalade Forums; Just curious as to what adjustment the plastic torx head on the platinum headlamp assembly performs ? Up/down or in/out ...
    murphy's Avatar
    murphy is offline Cadillac Owners Enthusiast
    Automobile(s): 2009 Cadillac Escalade Platinum
    Dec 2008
    Alberta,Canada
    813
    Just curious as to what adjustment the plastic torx head on the platinum headlamp assembly performs ? Up/down or in/out or other and is this the only adjusting mechanism ?
    tia
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2012 Escalade, 2014 SRX
    Apr 2003
    H.V., Pa/Town of Webb, NY
    13,289
    Re: ? about Platinum headlamp adjustment screw
    Yes it is but you can not use a male torx like you can on the HID light adjustment of the standard Escalade, you have to use the female or external torx socket size E8, screwing in or down raises the lights if memory serves me correct, you just have up and down adjustment
    http://buy.snapon.com/catalog/item.a...e=&dir=catalog
    murphy's Avatar
    Dec 2008
    Alberta,Canada
    813
    Thanks Carl..I think a 10mm socket fits also..
    48Dodge is offline Cadillac Owners Fanatic
    Automobile(s): '08 Escalade ESV
    Mar 2011
    41
    442
    Just adjusted my non-platinum headlights this weekend. They were both way too high. I used a bit driver handle to make the adjustment. It fit the adjustment posts very snugly. I believe bit driver bits are 1/4"
  7. Remove Advertisements
